11-07-2017 03:01 AM - edited 03-08-2019 12:39 PM
I have been having problems with wifi with mainstream equipment in a home/apartment scenario (peak season - 3 apartments with several tens of devices using wifi) and am looking for something that works. For the switch, I have been considering new/used 3750G and SG300. Could someone
please comment whether one or the other of these switches or some other would have a greater advantage. The switch will be used to connect my home lab, NAS, 4 access points (for home and apartment users) , home automation and low speed internet (under 100Mbps)
Solved! Go to Solution.
11-07-2017 10:12 PM
I think the 3750G only supports poe and most environments will need at least poe+(especially newer access points). There are some sg300 models that support poe+ but if you need to enterprise grade switches, then i would look at the 3750X
John
11-07-2017 04:37 AM - edited 11-07-2017 04:41 AM
Both options are fine, the 3750G is most robust switch than SG300, but if you want to save energy you should compare the Amp or Watts used by each one. Lowest watts less consumption of energy.
Both switches are great but you need to compare the specs. My personal selection is the 3750G.
Hope it is useful
11-07-2017 10:12 PM
John
