Need some basic help configuring a CISCO892W-AGN-E-K9
fred.appelman
My knowledge is very basic so please bear me with me.
I just bought a CISCO892W-AGN-E-K9. This device has two indepent wireless antenna's, an 8 port internal switch plus two WAN links, 1 Gigabit Ethernet and a fast ethernet port and finally a backup ISDN line. I am not going to use the ISDN.
I am trying to get start with some very basic activity which is enabling the Gigabit Ethernet (or the FE, I don't care). My plan was to either give it a static IP address or a DHCP address. A DHCP server is present.
The first issue is that the WAN ports don't seem to be accessible. If I connect either of the WAN ports and power up the device they don't seem to be enabled, sending out DHCP or the like etc.
So I changed strategy and connected one of the internal switch ports. That works. It apparently does an DHCP over the 8 port switch and it does get an IP and so I can use telnet to login to the device. I am missing some converter so I haven't been able to use the console port.
So when I log in into the device I do find the GE but I can't find the FE or the switch port.
cisco-ap#show interfaces summary
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface              IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
* BVI1                     0     0    0     0  2000    2     0    0    0
  Dot11Radio0              0     0    0     0     0    0     0    0    0
  Dot11Radio1              0     0    0     0     0    0     0    0    0
* GigabitEthernet0         0     0    0     0  3000    3     0    0    0
So it seems that the GE interface is connected to the internal switch. Where are my wlan ports?
Any help is appreciated. Just to be sure I'll append the show interfaces output and the running config (which is the default config).
     Fred
If I ask for the a list of interfaces using the ? I get:
cisco-ap#show interfaces ?
  Async               Async interface
  BVI                 Bridge-Group Virtual Interface
  CDMA-Ix             CDMA Ix interface
  CTunnel             CTunnel interface
  Dialer              Dialer interface
  Dot11Radio          IEEE 802.11 WLAN
  GigabitEthernet     GigabitEthernet IEEE 802.3z
  Loopback            Loopback interface
  Multilink           Multilink-group interface
  Null                Null interface
  Tunnel              Tunnel interface
  Vif                 PGM Multicast Host interface
  Virtual-Dot11Radio  Virtual Dot11 Interface
  Virtual-PPP         Virtual PPP interface
  Virtual-Template    Virtual Template interface
  Virtual-TokenRing   Virtual TokenRing
  accounting          Show interface accounting
  counters            Show interface counters
  crb                 Show interface routing/bridging info
  dampening           Show interface dampening info
  description         Show interface description
  irb                 Show interface routing/bridging info
  mac-accounting      Show interface MAC accounting info
  mpls-exp            Show interface MPLS experimental accounting info
  precedence          Show interface precedence accounting info
  rate-limit          Show interface rate-limit info
  stats               Show interface packets & octets, in & out, by switching path
  summary             Show interface summary
  switching           Show interface switching
  |                   Output modifiers
  <cr>
The running config:
Current configuration : 2997 bytes
version 12.4
no service pad
hostname cisco-ap
logging rate-limit console 9
enable secret 5 $1$cKpt$CwBHMRNrOKECVze4A5o66.
no aaa new-model
dot11 syslog
username cisco privilege 15 secret 5 $1$SGEn$qSAJ1dmxlz/GhYKMLjG4T.
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
banner exec ^CC
% Password change notice.
Default username/password setup on AP is cisco/cisco with privilege level 15.
It is strongly suggested that you create a new username with privilege level
15 using the following command for console security.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to
use. After you change your username/password you can turn off this message
by configuring  "no banner login" and "no banner exec" in privileged mode.
^C
banner login ^CC
no username cisco
^C
line con 0
privilege level 15
login local
no activation-character
line vty 0 4
login local
cns dhcp
end
15 Replies 15
fred.appelman
Some good news. As I said in the original post I wasn't using the console port. This turns out to make a big difference.
If I run the command "sh ip interf brief" from a telnet session I get:
cisco-ap#sh ip inter brief
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       10.0.83.99      YES DHCP   up                    up
Dot11Radio0                unassigned      YES NVRAM  administratively down down
Dot11Radio1                unassigned      YES NVRAM  administratively down down
GigabitEthernet0           unassigned      YES NVRAM  up                    up
where if I run the same command on the console I get:
yourname#show ip int brief
BRI0                       unassigned      YES NVRAM  administratively down down
BRI0:1                     unassigned      YES unset  administratively down down
BRI0:2                     unassigned      YES unset  administratively down down
FastEthernet0              unassigned      YES unset  down                  down
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  down                  down
FastEthernet4              unassigned      YES unset  down                  down
FastEthernet5              unassigned      YES unset  down                  down
FastEthernet6              unassigned      YES unset  up                    up
FastEthernet7              unassigned      YES unset  down                  down
FastEthernet8              unassigned      YES NVRAM  administratively down down
GigabitEthernet0           unassigned      YES NVRAM  administratively down down
Vlan1                      10.10.10.1      YES NVRAM  up                    up
Wlan-GigabitEthernet0      unassigned      YES unset  up                    up
wlan-ap0                   10.10.10.1      YES unset  up                    up
For a starter - as I consider my self - this is highly confusing. Anyway although it turned out to be a wild goose chase I still appreciate the help I received.
