need some big time help
chr6is000
                   my router has taken a poop. it is in a constant loop when i start it up and loads the image, then i comapared it with another router to see where it malfunctions and this is where is does, it says;
00:00:10 UTC Fri Mar 1 2002: Unexpected exception to CPUvector 100, PC = 0x801BA270, LR = 0x801CD2F8
-Traceback= 0x801BA270 0x801CD2F8 0x801CC840 0x801CC01C 0x80105ED0 0x80101750 0x801CE010 0x801C91B8 0x801C9328 0x81708A1C 0x809F344C 0x809F372C 0x8064C76C 0x8064FE70
CPU Register Context:
MSR = 0x00009032  CR  = 0x22000024  CTR = 0x801CD2AC  XER   = 0x20005765
R0  = 0x00001032  R1  = 0x829EEDB0  R2  = 0x82650000  R3    = 0x00000003
R4  = 0x00000000  R5  = 0x00000000  R6  = 0x82650000  R7    = 0x68010000
R8  = 0x00009032  R9  = 0x82280000  R10 = 0x68010000  R11   = 0xC0000000
R12 = 0x22000022  R13 = 0xFFF4A9E4  R14 = 0x809F36E8  R15   = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19   = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000000  R23   = 0x00000000
R24 = 0x00000000  R25 = 0x00000000  R26 = 0x829EEDE0  R27   = 0x00000000
R28 = 0x00000000  R29 = 0x68000000  R30 = 0x00000000  R31   = 0x00000000
Free space check for flash:crashinfo_20020301-000010 failed (1016/1302)
=== Flushing messages (00:00:10 UTC Fri Mar 1 2002) ===
Queued messages
*** System received a SegV exception ***
signal= 0xb, code= 0x100, context= 0x82846ed0
PC = 0x801ba270, Vector = 0x100, SP = 0x829eedb0
15 Replies 15
Glad you got it fixed!  Consider marking this answered and rating so it can help other users if you are so inclined.
If this posts answers your question or is helpful, please consider rating it and/or marking as answered.
