need support with routing
edwincharles
Can anyone help me on the attached packet tracer lab.
I need to ping the mangement ip of switches - switch 1 and switch 2 from Router 0
8 Replies 8
Mark Malone
Hey you will get a quicker response if you post the configs from each device, we would need to have packet tracer running to be able to open that file.
hello mark,
as requested attached config
can you share to us how they are connected as well?
One thing i noticed is that you have the same management IP for all 3 switches. Is this a typo?
hi,
sorry it was a mistake, attached config with layout
you should have your trunks consistent the whole way through then when you know its working you lock it down , im seeing native vlan set on one side but not the other
set them all for now as just switchport mode trunk ,allow all vlans unless your using a 3rd party hub or something in the network that needs native set ?
native on 1 side and not the other will cause tagging issues
some stuff i notice. first your default route is pointed to a admin down interface on router0 (gi0/0) Next, you are trying to manage the devices via VLAN99 but to what i see, they are on a different interface. If you need to manage them, you need to point a /32 static route to Gi0/2 for the management IP's of SW1 and SW2, that is if they are connected via Gi0/2
edit: i would suggest you manage SW1 and SW2 using a different subnet since they are not on the same VTP domain as per your diagram
 i would like to keep same range for mgmt
i router 0, can let me know how to config the static route
sorry, i did a second look, i was wrong in saying static route would fix it.
i would suggest you connect SW2 to SW0 if you want to keep the management IP's.
If you want to manage it with the same setup/connections, you need to assign a new management IP to SW1 and SW2 within the same subnet as Gi0/2 since the L2 switches has no idea how to reach Gi0/1.99 from Gi0/2 connection.
