Stacking cisco 2960 question
Bedevere Curry
Level 3
Level 3
Can this 2 switch be stacked and if not, is there any changes we have to do to make it stack?
The switch we need to add:
WS-C2960-24TC-L
IOS - "flash:/c2960-lanbasek9-mz.122-50.SE5/c2960-lanbasek9-mz.122-50.SE5.bin"
Existing stack:
Switch name - missionkansas17-swt
Model - WS-C2960X-24PD-L
IOS - "flash:/c2960x-universalk9-mz.150-2.EX3.bin"
2 Accepted Solutions
Hi Bevedere,
WS-C2960-24TC-L does not support stacking.
WS-C2960X-24PD-L does support stacking and can be stacked with another switch of  the same family(2960X) or 2960S.
HTH,
Roopa
Hi Bevedere,
2960 does not even support stacking. This is why you probably dont see any document also.
Roopa
6 Replies 6
Bedevere Curry
Level 3
Level 3
I see this link and it mentions 2960s but not 2960. Since its same stackwise, I would imagine it works but one is running lanbase and one is universal so I don't know if it will work?
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/white_paper_c11-728327.html
Hi Bevedere,
HTH,
Roopa
Cisco(r) Catalyst(r) 2960-X Series Switches are the next generation of the world's most widely deployed access switches. They enable intelligent services such as application visibility, Smart Operations, Layer 3 routing and deliver best-in-class energy efficiency with up to 80 percent energy savings. Designed for operational simplicity to lower TCO, this platform also offers investment protection with mixed stacking with existing Cisco Catalyst 2960-S and 2960-SF switches.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/product_bulletin_c25-728262.html
I don't see any support between C2960 and C2960X but C2960X works with 2960-S and 2960-F. I haven't found any confirmation that 2960x works with 2960 and if you run into it, please do let me know. Thanks
Hi Bevedere,
Roopa
Thanks guys for your information.
Thanks Roopa.
