04-20-2018 09:02 PM - edited 03-08-2019 02:44 PM
Hi Freinds
Kindly Find Attachment
Have same scenario , need to connect L3 Router to vPC Domain , HSRP is running for GW
Thanks all
04-21-2018 12:13 AM
As I remember that VLAN State and IP address configuration is coming under the "Configuration Parameters That Must Be Identical". Can you check VLAN 10 IP address configuration on both VPC member?
I am confused, If I am wrong, please reply.
Deepak Kumar
04-21-2018 05:11 AM
The solution to your question is in the picture you attached:
2 physical links into your router, one to each nexus.
no port channel.
HSRP between the two nexus switches
04-21-2018 12:41 PM
Hi Dennis ,
why y r saying no PC , while the pictures show vPC from each nexus down to router
thanks
04-21-2018 08:48 PM
The picture is not showing you should use vPC, it just shows that you need to use layer-3 links between the router and the switches with no Portchannel or vPC.
