net setup problem
julxu
I have a problem to setup nat for a machine.
we have machine need open port, said, 11111. the machine is on privite network 192.168.0.0/24.
there is a cisco 2000 router configure this subnet, and link it to main router cat6500, with a public ip add. we said the public adress is
10.1.1.1/24 and 10.1.1.2/24
I have did net on cisco 2000 as:
interface GigabitEthernet0/0.192
ip nat inside
ip nat outside
ip nat inside source static tcp 192.168.0.111 11111 10.1.1.10 10001 extendable
after I have done this, the cat6500 and related area working find.
but, the cat6500 connect to cat6500-2, which link to internet, and both cat6500-2 area and internet can get ping, but not anything else
so, I thought, I may need put nat at cat6500
I have done:
for cat 6500
interface G0/1
desc link to cat6500-2
ip address 10.2.1.0/30,
ip nat outside
but it not works on cat6500-2 and related area, that means:
    when I use <telnet nat-ip-address 111111> no connection
    ping nat-ip-address -> ok
can anyone advice me if I have nat issue, or something else?
any comments will be appreciated
thanks in advance
julxu
Carlos Amador
julxu,
According to your NAT
11111 is the port the real ip address is using, so you should be trying to connect to 10001 which is the one configured for the public IP, that should be translated to the real port and IP
