Netflow 3850 switch - prtg
carl_townshend
Hi All
I have configured netflow on my 3850 to send to PRTG, However it doesn't seem to be showing anything
I have a routed vlan to my firewall which I want to monitor
how should I do this?
cheers
Julio E. Moisa
is there communication between the PRTG and the switch, ping or traceroute? could you please share the netflow configuration?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes there is comms
flow record FLOW-RECORD-IN
 match ipv4 tos
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 match interface input
 match flow direction
 collect interface output
 collect counter bytes long
 collect counter packets long
flow record FLOW-RECORD-OUT
 match ipv4 tos
 match ipv4 protocol
 match interface output
 collect interface input
flow exporter PRTG-IN
 destination 10.1.1.1
 source Vlan2403
 transport udp 2055
flow exporter PRTG-OUT
 source Vlan2403
 transport udp 2055
flow monitor FLOW-MONITOR-IN
 exporter PRTG-IN
 cache timeout active 60
flow monitor FLOW-MONITOR-OUT
 exporter PRTG-OUT
vlan configuration 2403
ip flow monitor FLOW-MONITOR-IN input
ip flow monitor FLOW-MONITOR-OUT output
Have you tried adding the following commands on the physical port the firewall is connected to:
thanks
John
**Please rate posts you find helpful**
Have you tried using Paessler's "netflow tester"?  It's a simple netflow receiver that you can use to see if the flows are arriving at the PRTG server at all.
If you don't see any flows in the test tool, then the problem is either with the switch or something between the switch and the PRTG server.
If you do see flows with the test tool, but not inside PRTG, then the problem is the PRTG configuration.
And, one more tip: inside PRTG, please put the netflow sensor on the probe device, not on the switch.  Only after it's working at the probe level, move it down to the switch. If it works at the probe level but not at the switch level, then the problem is probably a hidden filter that PRTG uses in flow sensors.  PRTG filters out all flows except those that come from the IP address that PRTG is using for that switch.  If the flows appear to come from a different address than the one PRTG is using, then they all disappear when you move the sensor to the switch.  Is this perhaps the behaviour you're seeing?
