Two different IP Addresses for the same MAC Addresses. Impossible to ping one of them...
Bruno Silva
Hi fellows,
i'm wondering what is escaping to me but, having the following schema:
My question is, it's possible ping both IP being the same mac-address? if i clear the arp table, i ping the first one with 192.168.111.101 IP and after that i can ping 192.168.111.102 but, if i try to ping again 192.168.111.101 it's not possible until i clear again the arp table...
Can you suggest something, please?
thanks in advance!
Reza Sharifi
So, the "user-end equipment" has 2 NICs?
Are they configured in HA (High Availability) mode?
Hi Reza,
Yes. I can call it 2 NICs. One equipment with two ethernet ports but both with the same mac-address.
They do not have availability configuration mode. The objective is to work, or be used, one at a time...
thanks
So, with this type configuration, does the redundancy work as expected?
Another word, if you disconnect one of the cables/NICs, does the other NIC take over packet forwarding? Do you have the same issue if you just connect one NIC?
Yes, Reza!
The redundancy works fine... it means, when i disconnect one of the cables/NICs, the other takes over packet forwarding and one mac-address entry table is added. Same MAC-ADDRESS, with other IP.
To return to inicial IP, i have to clear manually the second mac-address entry table...
Thanks for your support!
