NetFlow Catalyst 3560
castorcete
Community Member
Hi All ,
It is possible to configure the IOS NetFlow 122-58.SE2 in a Catalyst 3560?
thank you very much
7 Replies 7
Giuseppe Larosa
Hello Carlos,
netflow is not supported on C3560.
in 12.2(58)SE  most netflow commands are listed
n unsupported commands section
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_58_se/configuration/guide/swuncli.html#wp1093600
Hope to help
Giuseppe
Ok , Thanks!
itdesk
Community Member
It is compatible, but you need to upgrade your IOS to version 15 onwards, and you should have software license for IPBase or IP Services features.
And after that you should buy an extra module called Services Module, which gives you Flexibe Netflow out of band.
Hope it helps.
Dear'm from Argentina, I am needing to install a version of NetFlow to monitor traffic on my network, but I have to switch hardware are WS-C3560-48PS 12.2 (55) SE1 - WS-C2960S-24PS-L 12.2 (55) SE3 - C2950-I6K2L2Q4-M), Version 12.1 (22) EA1, nor can you update the IOS to monitor them and the other query is whether I also need to purchase any other module.
many Thanks
ysantizo1
Frequent Visitor
Frequent Visitor
I have a 3560 with IOS 15
I can configure it but it doesn't export anything
-3560G#sh ip flow export
Flow export v9 is enabled for main cache
Export source and destination details :
VRF ID : Default
Source(1) 192.168.168.250 (Vlan100)
Destination(1) 10.10.1.59 (9996)
Version 9 flow records
0 flows exported in 0 udp datagrams
0 flows failed due to lack of export packet
0 export packets were sent up to process level
-3560G#
Capistrano-3560G#sh ip cache flow
IP packet size distribution (0 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
IP Flow Switching Cache, 278544 bytes
0 active, 4096 inactive, 0 added
0 ager polls, 0 flow alloc failures
Active flows timeout in 1 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 33608 bytes
0 active, 1024 inactive, 0 added, 0 added to flow
0 alloc failures, 0 force free
1 chunk, 0 chunks added
last clearing of statistics 01:06:32
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
Here's the config:
interface GigabitEthernet0/6
ip flow ingress
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
ip flow ingress
interface GigabitEthernet0/10
ip flow egress
interface GigabitEthernet0/11
ip flow ingress
interface Vlan100
ip flow ingress
ip address 192.168.168.250 255.255.255.0
ip flow-export source GigabitEthernet0/1
ip flow-export version 9
ip flow-export destination 10.10.1.59 9996
I have a router exporting correctly its data.
Any ideas please??
Thanks in advance!
Regards.
 The 3560G does not support netflow even though the commands may be there. Cisco is notorious for leaving commands that arent supported in the different levels of code .
Collin Clark
The netflow module is only available in the 3750x's. You're out of luck.
Sent from Cisco Technical Support Android App
