Netflow for 4510R
Shao-Yu Chen
Trying to collect netflow from a 4510R, but I am not able to. Current software version for 4510R is cat4500-IPBASEK9-M 12.2(40)SG release software (fc2).
The running-config for ip flow...
ip flow-export source GigabitEthernet4/1
ip flow-export version 5
ip flow-export destination 10.x.x.x 2055
And the running-config for the interface gi4/1....
description - BHN-MetroEthernet -
no switchport
ip address 10.zz.0.yy 255.255.255.0
ip pim sparse-mode
ip multicast boundary mcast-boundary-acl
ip summary-address eigrp 1 10.yy.0.0 255.255.0.0 5
power inline never
speed 100
duplex full
qos trust dscp
flowcontrol receive on
What am I missing?
Thanks in advance for the help.
With SUP Engine V-10GE, NetFlow fucntionality is embedded. Have you tried configuring as below:
ip flow-export source GigabitEthernet4/1 \\ Any interface that can take the NetFlow packets to the server
ip flow-export version 7
ip flow-cache timeout active 1
ip flow ingress layer2-switched
ip flow ingress infer-fields     \\ If your IOS does not support this, use 'ip route-cache flow infer-fields'
Don Thomas Jacob
http://www.solarwinds.com/netflow-traffic-analyzer.aspx
NOTE: Please rate and close questions if you found any of the answers helpful.
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
glen.grant
  What supervisor do you have?  Do you have a netflow services card installed.  Seeing you have ipbase it probably won't support netflow on that version either.
We have 2 sup module in this chassis, and both are WS-X4516-10GE. Not sure if there is a netflow services card. Will I be able to find that out from CLI? What IO version should I get to get netflow to work?
Thank you for the help.
Don Thomas Jacob
It worked, but I have to stay with ip flow-export version 5. BIG THANK YOU!
