Netflow for IPv6
I have setup flexible netflow v9 for our ipv6 traffic on a Cisco ASR1000 and I've struck a problem where no source or destination ipv6 addresses are being recorded.  IPv4 with version 5 is working fine though.
Here is the configuration that I'm applying - am I missing some config?
flow exporter ipv6-export
 destination x.x.x.x
 source Loopback88
 transport udp 6100
flow record IPv6-RECORD
 match ipv6 traffic-class
 match ipv6 protocol
 match ipv6 source address
 match ipv6 destination address
 match transport source-port
 match transport destination-port
 match flow direction
 collect routing source as
 collect routing destination as
 collect ipv6 dscp
 collect ipv6 source mask
 collect ipv6 destination mask
 collect transport tcp source-port
 collect transport tcp destination-port
 collect transport tcp flags
 collect interface input
 collect interface output
 collect counter bytes
 collect counter packets
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
flow monitor ipv6-monitor1
 record IPv6-RECORD
flow monitor ipv6-monitor2
 record IPv6-RECORD
int ten 0/01.1001
ip flow monitor ipv6-monitor1 input
ip flow monitor ipv6-monitor2 output
And here's the output that I'm getting from the router:  It's not the best for readability, however, the ' :: ' is where I wold expect the src and dest address to be.
80           5080  Output           6  0x00        24246          0             /0             /0
    80          5080  0x12       Te0/0/0.4005           Te0/0/1.001                    52           1  11:0
9:16.212  11:09:16.212  0x00
Any assistance would be appreciated (I hope this isn't a bug...)
Jono
0 Replies 0
