Netflow on 3750 switches
jfeo
I am trying to configure Netflow on cisco 3750 switches
using this configuration
flow exporter FLOW
 destination xx.xx.xx.xx
 transport udp 2055
 template data timeout 60
flow record v4
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 collect counter bytes
 collect counter packets
3750_switch(config-if)#ip flow monitor ?
No monitors configured
  <cr>
Ganesh Hariharan
flow exporter FLOW
transport udp 2055
flow record v4
match ipv4 protocol
  <cr>
Have you checked the below link for flexible net flow configuration in cisco 3750 switches.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/configuration/guide/3750xcg/swmnetflow.html#pgfId-1335599
Hope it Helps..
-GI
Rate if it Helps..
Yes I have I never get any flows. I wonder if this platform supports netflow
roor
What flavour of 3750 are you trying this on? Netflow is supported only on 3750X and on the C3KX-SM-10G module only.
Roopa
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The "C3KX-SM-10G" supports FNF.  Unsure what other Netflow, if any, is supported w/o this service module.
