Network cabling
jonk34567
Level 6
Level 6
In practical world what cable is used to connect a router to router ?
11 Replies 11
Reza Sharifi
It depends on the router and the distance. If the distance is less than 100 meters and the routers have copper ports (most do) you can connect them via copper.  If the distance is more than 100 meters and has fiber ports, fiber cable is used to connect them.
what do you mean by copper cable.serial cable ?
Copper cable is usually named for UTP Cat cables. Other name is twisted pair cable.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Copper cable is the type cable that connects your computer to the wall jack in your LAN environment. This is if you are not using wireless.
Julio E. Moisa
As Reza mentioned it could depends of the distance and the type of port but if you are going to connect 2 routers directly one next the other through ethernet port you can use a crossover cable.
Hope it is useful
Leo Laohoo
Hey Jonk,
Haven't seen you for some time.   How did your last Q&A go?  Did you get good grades out of it?
Like any network device, connection can be done in several methods:
  1. Copper cable;
  2. Fibre optic cable;
  3. Radio; and
  4. Satellite (see IRIS)
Hehehehe
Tausif Gaddi
Level 5
Level 5
You can use SFP or Copper depending on the router ports. Cat cables / twisted pair cable are copper cables commonly used.
jwdoherty
Level 4
Level 4
Today, it's often Ethernet cables of some type, but one of the features of routers is very general media support, so you may find all kinds of cables used, especially when dealing with "WAN" connections.
For example, in your later post, you mention "serial".  That's often a cable to connect to something that works with a Telco's ("slower") WAN links.
Kin Loo
Community Member
Crossover for FastE or GigE or simply just use serial cables.
ryansmith22014
Community Member
Ethernet cable are specially designed for connecting two computers to each other or to connect router to router. Mostly Ethernet cables are designed to connect one computer to a router or switch. Ethernet cables are physically manufactured in two basic forms called solid and stranded.
An Ethernet cable is one of the most popular forms of network cable used on wired networks. Ethernet cables connect devices together within a local area network, like PCs, routers, and switches. To install, test, troubleshoot and certify ethernet cable you need specific ethernet cable testing tool.
Fluke Networks offers many cable testing tools for cable verification.
Fluke Networks copper qualification tester troubleshoots and qualifies Ethernet network cabling speed (10/100/1000/VoIP).
