Nexus 7000 , OTV internal interface
HUBERT RESCH
Level 3
Level 3
We have deployed OTV to strech VLAN accros Datacenters.
The internal interface now are either access-ports of the particula Vlans or dot1Q-trunks.
Now I got the question if it is possible to use a dot1q-Tunnel-Port as internal interface. I am really not sure if this would work,
any idea out there ?
Thx
Hubert
s-durando
Hi Hubert,
did you have the opportunity to test this configuration of dot1q tunnel on the OTV internal interface?
Kind regards
Stefano
