Network micro cut for kyocera printers connect to the switch cisco
ksoltani
I have kyocera printers connected with network cable linked with Cisco switch C9300-48UXM authenticated with ISE server communicates with WMS application server
all printers connected ok saif two printers, I do a continuous ping for the printers it works
my manager told me to check if there is a micro cut or something like that
I wanted to know how for the troubleshooting, it is koi the command necessary to check if there is a micro cut problem or slowness in the networks
balaji.bandi
can you explain - Network micro cut ?
BB
hi @balaji.bandi
in an industrial environment, we use printers that communicate with application servers
in my network side when I do ping test for the printers, it is operational and accessible
problem for some kyocera printers not all printers
my manager does not understand who is not a network problem
my question is koi as debug or troubleshooting at the switch level shows which is not a network problem
Switch model "UXM" means mGIG port.
Is there a switch in the stack that can support 10 Mbps?
