networking Lab
shanej2118
Wasup! I'm doing a lab on cisco packet tracer and I'm assigning Ip addresses. one step says Assign the last usable  address of subnet 6 to the office 1 network CEO end devices. Also, assign a subnet mask and the default gateway ( first  address in the subnet) can I get some help on this please
23 Replies 23
Beautiful!
I was giving this. my pcs on office 1on R1 and on office on R2 were assigned there Ip address. As you can see the gig lines to both office are red why might that be?
I am on step 9, im unable to assign any ip address to my device for that server
Save your PaccketTracer file, zip it and attach here. Let me take a look.
Holy sh*t the converting the pk file to zip worked I had no idea... i have sooo much to learn , i sent the file
I got the file. I will take a look and share with you.
 You need to finish configuring your router.  CEO1 can ping the gateway but you did not finish configuring the subinterface for vlan 20 and 30
You need to create the subinterface GigabitEthernet0/0.30, assign IP and assign IP do GigabitEthernet0/0.20
R1#sh ip int br
GigabitEthernet0/0 unassigned YES NVRAM up up
GigabitEthernet0/0.10 172.16.10.161 YES manual up up
GigabitEthernet0/0.20 unassigned YES unset up up
done.
done.
Switch S1-Office1,  interface Fa0/2 needs to be trunk and not access.
You can check my file. It is working. All PCs is piinguing the gateway
