networking Lab
shanej2118
Wasup! I'm doing a lab on cisco packet tracer and I'm assigning Ip addresses. one step says Assign the last usable  address of subnet 6 to the office 1 network CEO end devices. Also, assign a subnet mask and the default gateway ( first  address in the subnet) can I get some help on this please
23 Replies 23
 Sure you can get help here. But you need to provide more information.
Attach your project here, just zip it before attach.
The last usable IP address depends on the mask. For example
192.168.1.0 with mask 255.255.255.0 the last usable IP would be 192.168.1.254.
Thank youu!! so much I'm dedicated to learning networking.
I'm stuck under Assigning Ip address step 6, I assigned an Ip address to my device office 1, but I'm not understanding the Note. where it states Also assign a subnet mask and the default gateway (first address in the subnet ) ?? what does the lab mean by that
You are expected to take the 172.16.0.0/24 and divided into 8 subnetworks, right?
Here it is, 8 subnetwork.
Network Address Usable Host Range Broadcast Address:
172.16.10.0 172.16.10.1 - 172.16.10.30 172.16.10.31
172.16.10.32 172.16.10.33 - 172.16.10.62 172.16.10.63
172.16.10.64 172.16.10.65 - 172.16.10.94 172.16.10.95
172.16.10.96 172.16.10.97 - 172.16.10.126 172.16.10.127
172.16.10.128 172.16.10.129 - 172.16.10.158 172.16.10.159
172.16.10.160 172.16.10.161 - 172.16.10.190 172.16.10.191
172.16.10.192 172.16.10.193 - 172.16.10.222 172.16.10.223
172.16.10.224 172.16.10.225 - 172.16.10.254 172.16.10.255
6 Assign the last usable addresses of subnet 6 to the Office1 network CEO end devices. Also, assign a subnet mask and the default gateway (first address in the subnet).
Subnet 6 is: 172.16.10.160/27 (255.255.255.224)
Office 1 is connected to R1. You need to assign one IP address to the Router´s interface GigabitEthernet 0/0:10. You can use 172.16.10.161 255.255.255.224 (First address of the subnet)
Last usable address of this subnet, you assign to  PCs.
IP:172.16.10.162
Mask: 255.255.255.224
Gatewa:172.16.10.161
IP:172.16.10.163
172.16.10.164
172.16.10.165
172.16.10.166
172.16.10.167
ahh okay! once in the router CLI, en, config t, interface gig 0/0.10, Ip Address 172.16.10.161. 255.255.255.224, now do i open access that interface to trunk and then encapsulation the with dot1q, then exit or just exit after input of Ip address then assign the rest of the subnet range to the other pcs in office 1
config t
encapsulation dot1q 10
Ip Address 172.16.10.161 255.255.255.224
end
This is it to router
cool, how do I assign ip addresses to the pcs on that network now.
I do it through the routers CLI ? now assigning to CEO 1 , Copyrightre 1 & Dialer 1 what are th cmd for assign those pics ?
No. Double Click on the PC and open the configuration window.
 There you add IP, mask and gateway
okay got it
where does the default gateway input ?
Use the Desktop tab.
