Port-Channel No Auto Nego Over Physical Port Auto Nego
Desmond Lee
Hi, I notice that when configuring Port-Channel, the configuration statement "No Auto Negotiation" would appear by default.
Say I have ports with "Auto Nego" under this PO, which one would take precedence ?  The PO's No Auto Nego or the physical ports "Auto Nego" settings ?
Desmond
The links associated with the port-channel should inherit the Port-channel interface configuration.
-david
Which SW is this ?
pardon me, its not a switch.  It's a 4431 router.
PROTECHIT
Hello
Like David Ruess said - "The links associated with the port-channel should inherit the Port-channel interface configuration."
A few days ago I was configuring port-channel between C9200L and SX350X switches. The key setting was to set the speed parameter to nonegotiate on both sides of port-channels.
Maybe this will be helpful.
Regards.
