Newbie setting up 3650
Jimbob1986
Hi all
Sorry if this is a really simple question, but i will have limited time with my new equipment to test before i must deploy.
I will be setting up 2 x WS-C3650-24TD-S switches with a very basic configuration. A single VLAN needs to span across the two switches (using a fiber trunk link), but i am not certain how to set this up...
After digging around i have seen mention that by default VLAN info is shared over the trunk link, but I assume some setup will be required on the 'slave' switch? I have read a bit about VTP, but not certain this is required for my basic setup?
The only other things i will need to configure to run on my VLAN (not sure if this is relevant) are:
  1. Local igmp v2, Local igmp snooping, Local igmp snooping querier,
  2. Local DHCP address pool
  3. Range of static addresses
Thank you for any help, and sorry if i sound a little naive - I am!
15 Replies 15
Jimbob,
Yes, you do need to exclude the addresses that you want to use as static ones. This is done by the command I included in the DHCP bit
ip dhcp excluded-address 192.168.100.1 192.168.100.10
This command excludes first 10 IP addresses from your DHCP pool. You can specify a wider range if you need more room for statics.
