10-31-2019 02:45 PM - edited 10-31-2019 02:46 PM
I have a pair of Nexus 3548's that during nmap scans of even a single host on any subnet or, even during the transfer of a bin file for upgrading the OS, I will get error like this in the secondary peer:
%STP-2-VPC_PEER_LINK_INCONSIST_BLOCK: vPC peer-link detected BPDU receive timeout blocking po10 vlan 100
then
%STP-2-VPC_PEER_LINK_INCONSIST_UNBLOCK: vPC peer-link inconsistency cleared unblocking po10 vlan 100
po1 being the peer link (4x 10ge links)
I'll get this for random vlans on the peer link...
Thing is, there is no inconsistency, I checked all parameters and consistency comparison commands as well.
The fact that even transferring a bin file to the switch triggers this is alarming.
Any ideas of what to look for or what would cause this?
We are running n3500-uk9.6.0.2.A8.11b on these switches (these are 3648p's a few years old)
10-31-2019 03:08 PM
As per the below message, you have Spanning Tree configuration issue :
Can you have both the switches configuration ? to verify and check what is wrong?
10-31-2019 03:55 PM
10-31-2019 03:55 PM
10-31-2019 03:57 PM
Posted the configs of each switch... Any help is appreciated.
10-31-2019 06:32 PM
virtual1# show vpc consistency global Legend: Type 1 : vPC will be suspended in case of mismatch Name Type Local Value Peer Value ------------- ---- ---------------------- ----------------------- QoS 2 ([], [], [], [], [], ([], [], [], [], [], [], [], []) [], [], []) Network QoS (MTU) 2 (9216, 0, 0, 0, 0, 0, (9216, 0, 0, 0, 0, 0, 0, 0) 0, 0) Network Qos (Pause) 2 (F, F, F, F, F, F, F, (F, F, F, F, F, F, F, F) F) Network Qos (WRED) 2 (F, F, F, F, F, F, F, (F, F, F, F, F, F, F, F) F) Network Qos (ECN) 2 (F, F, F, F, F, F, F, (F, F, F, F, F, F, F, F) F) Output Queuing (Bandwidth) 2 (100, 0, 0, 0, 0, 0, (100, 0, 0, 0, 0, 0, 0, 0) 0, 0) Output Queuing (Absolute 2 (F, F, F, F, F, F, F, (F, F, F, F, F, F, F, Priority) F) F) STP Mode 1 Rapid-PVST Rapid-PVST STP Disabled 1 None None STP MST Region Name 1 "" "" STP MST Region Revision 1 0 0 STP MST Region Instance to 1 VLAN Mapping STP Loopguard 1 Disabled Disabled STP Bridge Assurance 1 Enabled Enabled STP Port Type, Edge 1 Normal, Disabled, Normal, Disabled, BPDUFilter, Edge BPDUGuard Disabled Disabled STP MST Simulate PVST 1 Enabled Enabled HW profile Forwarding Mode 1 normal normal IGMP Snooping Group-Limit 2 8190 8190 Interface-vlan admin up 2 37-38,301,570,577,590, 37-38,301,570,577,590, 880,980-983,1030-1031, 880,980-983,1030-1031, 1033,1035,1037-1038,10 1033,1035,1037-1038,10 40,1045,1047,1050,1055 40,1045,1047,1050,1055 ,1063,1070 ,1063,1070 Interface-vlan routing 2 1,37-38,301,333,411,57 1,37-38,301,333,411,57 capability 0,577,590,880,980-983, 0,577,590,880,980-983, 1030-1031,1033,1035,10 1030-1031,1033,1035,10 37-1038,1040 37-1038,1040 Allowed VLANs - 1,37-38,88,95-96,99,11 1,37-38,88,95-96,99,11 8,126,150,195,199,219- 8,126,150,195,199,219- 220,224,300-301,333,41 220,224,300-301,333,41 1,500-501,520,560,570, 1,500-501,520,560,570, 577,580,590,600,666,80 577,580,590,600,666,80 1-805,880,980-983,1030 1-805,880,980-983,1030 -1031,1033,1035,1037-1 -1031,1033,1035,1037-1 038,1040,1045,1047,105 038,1040,1045,1047,105 0,1055,1063,1070 0,1055,1063,1070 Local suspended VLANs - - - virtual1#
virtual1# show vpc consistency-parameters vlans Name Type Reason Code Pass Vlans ------------- ---- ---------------------- ----------------------- STP Mode 1 success 0-4095 STP Disabled 1 success 0-4095 STP MST Region Name 1 success 0-4095 STP MST Region Revision 1 success 0-4095 STP MST Region Instance to 1 success 0-4095 VLAN Mapping STP Loopguard 1 success 0-4095 STP Bridge Assurance 1 success 0-4095 STP Port Type, Edge 1 success 0-4095 BPDUFilter, Edge BPDUGuard STP MST Simulate PVST 1 success 0-4095 Pass Vlans - 0-4095
