02-14-2011 03:04 AM - edited 03-06-2019 03:31 PM
Problem
FEX hangs on "Image download"
current version
kickstart: version 4.1(3)N2(1)
system version 4.1(3)N2(1)
feature Fex enable
fex association 100
1. Is this syntax correct?
2. Then what is the next step after I get image to 5010
Getting
Nexus_5010# copy tftp://10.1.2.2/n5000-uk9.4.2.1N2.1.bin/n5000-uk9-kickstart.4.2.1.N2.1a.bin bootflash: vrf management
Connection to server established
TFTP get operation failed:File not found
v/r
mr
Solved! Go to Solution.
02-14-2011 03:38 AM
Syntax looks correct; once you get the image on the N5K, type "install all" and it will install the images you have just copied.
That should sort you out..
02-14-2011 03:38 AM
