Nexus 5548UP and DS-SFP-FC4G-SW (4G Fiber Channel)
9ball
My 5548UP won't recognize my DS-SFP-FC4G-SW transceivers.  The Storage license is installed and the `feature fcoe` is enabled.  The transceiver LED stays amber, `show interface` says the transceiver is of type "Unknown", and `interface fc x/y` does not work.  (substitute any value for x/y).
There's nothing in the documentation, that I've found, explaining a configuration procedure to get the Nexus to recognize the transceivers, other than enabling the FCOE feature, which I have done.  Am I missing something, or does my 5548UP not support these Fiber Channel transceivers?  After all, this is *why* I got the 5548UP without any expansion modules.
Any help here would be nice.
Mike.
5 Replies 5
Roman Rodichev
Level 7
Level 7
are you running latest 5.0(3)N1(1c) ?
It shipped with 1b. I didn't see 1c for download on Friday. Was it just released?
I read the release notes, but there isn't anything in there regarding this. Are you referring to a specific bug that's fixed in 1c?
Upgraded to 1c; no change (no surprise).  I'll have to open a TAC case, I guess.
Please let me know what you find out, I'm curious! I don't even see 5.0(3) SAN Switching configuration guide on CCO yet! I love it when Cisco's documentation appears on CCO some time after FCS
9ball
I guess they forgot to make the requisite documentation public.  It should be forthcoming, as the documentation team is now aware of it.
Here's what TAC walked me through:
The tech mentioned that there are some limitations or restrictions as to groups of ports that can be configured together, so it may be best to wait for the documentation or open your own TAC case before doing this.  Also note that a reload is required each time a port type is changed.
n5548up(config)# slot ?
  <1-199>  Enter a slot number
n5548up(config)# slot 1 ?
n5548up(config-slot)# ?
  beacon     Beacon
  no         Negate a command or set its defaults
  port       Configure a port
  provision  Pre-provision a module in this slot
  end        Go to exec mode
  exit       Exit from command interpreter
  pop        Pop mode from stack or restore from name
  push       Push current mode to stack or save it under name
  where      Shows the cli context you are in
n5548up(config-slot)# port ?
  <1-199>  Enter a port range
n5548up(config-slot)# port 29 ?
  -     Range separator
  type  Configure a port type
n5548up(config-slot)# port 29 - ?
n5548up(config-slot)# port 29 - 32 ?
n5548up(config-slot)# port 29 - 32 type ?
  ethernet  Ethernet Port
  fc        FC Port
n5548up(config-slot)# port 29 - 32 type fc ?
n5548up(config-slot)# ^Z
n5548up# reload
