Nexus 5548UP VPC and/or VRRP problem
Hi, I have two 5548UP + L3 card with LAN_ENTERPRISE_SERVICES_PKG and FC license.
This two Nexus are the core of my network.
Eight stacks of 2960S are connected to both NX with an etherchannel formed by two SX-1G or two SR-10G.
I've checked the conf and maked a lot of test and everything works fine. BUT, two days after the people start working on the new building, about half of the PC don't even reach the default gateway. (Nexus VRRP)
I've turned off VRRP and it works for minutes.
The problem disappear if I shutdown one of the links to NX01 or NX02.
I followed the destination MAC of one PC with the problem and the ARP table looks OK but I guest the problem is related with a corruption in the ARP table anyway.
system image file is:   bootflash:///n5000-uk9.5.2.1.N1.1a.bin
Thanks in advance!
Guido./
interface Vlanxx
  no shutdown
  ip address 10.xx.xx.1/24
  ip ospf passive-interface
  ip router ospf 1 area 0.0.0.0
  ip dhcp relay address xxxxx
  vrrp 80
    address 10.xx.xx.1
! Actualy is in shutdown
interface port-channel55
  switchport mode trunk
  switchport trunk allowed vlan 1-300,303-4094
  ip dhcp snooping trust
  speed 10000
  vpc 55
interface port-channel111
  switchport trunk allowed vlan 1-224
  spanning-tree port type network
  speed 10000
  vpc peer-link
8 Replies 8
Reza Sharifi
What is the output of "sh vpc"?
and sh vpc con global?
Hi Guido
First your VRRP configuration looks a bit strange. Could you please post the config of your interface vlan10 from both core Nexus Switches?
Second thing: It look's like you don't allow all vPC Vlans on your peer link - That may be not related to your problem, but maybe there's a vPC issue.
Please post SVI 10 and vPC configuration.
/Marcel
  Hi, in the attached file I've pasted the sh vpc commands and the full conf of int vl80.
vPC peer link has filtered vlans 225,301 and 302 because they are used for VSAN and my VSANs are local on each Nexus.
Guido./
ajay chauhan
Level 7
Level 7
Looks like you have configured same IP on physical and for standby. is this typo or configured on device ?
!----------- NX01 ----------------------------------------------
interface Vlan80
  no shutdown
  ip address 10.xx.80.1/24
  vrrp 80
    address 10.xx.80.1
!----------- NX02 ----------------------------------------------
!NX02
interface Vlan80
  no shutdown
  ip address 10.xx.80.2/24
  vrrp 80
    address 10.x.80.1
Also -Peer Gateway                      : Disabled
Optional but can be turnon to make both in forwarding mode.
Ajay
Hi, in VRRP you can use the same ip for virtual and phisical. The router with the IP of the VRRP, is alwals the primary (obviously!).
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_2/nx-os/unicast/configuration/guide/l3_vrrp.html#wp1074713
And I followed this note
"Note
You should configure VRRP on the primary vPC peer device as active and VRRP on the vPC secondary device as standby."
Guido
Can you change the physical interface on NX01 to a different IP and not the same as the virtual IP and test again?
ezy
Hi Guido,
did you solve that problem? And how did you do it? I have a simliar problem with arp entrys.
Thanks in advance
Erich
Hi Eric,
yes I solved this problem and another one which was  related to Windows 2003 DHCP server and option 82.
The ARP/VRRP problem was solved using  peer-gateway and ip arp synchronize.
This is my final config:
vpc domain 11
  role priority 1
  peer-keepalive destination y.x.x.6 source y.x.x.5
  delay restore 150
  peer-gateway
  auto-recovery reload-delay 300
  ip arp synchronize
please drop a line if this help you!
Guido.
