Nexus 5672UP fc not working
JeremieBelpois
I am trying to configuration the FC feature on my Nexus 5672UP, everything seem okay but after zoneset activated, nothing happend, server and SAN controller did not see each other.
My step:
- Enable FCoE feature
- Change unified port range to type FC
- Reload chassis
- Plug port from SAN and Server HBA
- Config zone and assgin the members as pwwn of SAN and Server HBA
- Add zone to zoneset and activated zoneset
Did I miss something ?
5 Replies 5
marce1000
 - Ref : https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/licensing/guide/b_Cisco_NX-OS_Licensing_Guide/b_Cisco_NX-OS_Licensing_Guide_chapter_01.html
          I am not sure if this needs a license or not , -> check Table 16
 M.
My switch also have installed there features of Storage Protocols Services Package:
FC_FEATURES_PKG
ENTERPRISE_PKG
balaji.bandi
High level those steps should work - now time for troubleshopot and post the outcome here to understand the issue :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/troubleshooting/guide/N5K_Troubleshooting_Guide/n5K_ts_sans.html
Along with relavant port config should helpfull.
BB
Here is my configuration:
switch(config)# show feature | grep fcoe
fcoe                  1         enabled
fcoe-npv              1         disabled
switch(config)# sh int brief
Interface  Vsan   Admin  Admin   Status          SFP    Oper  Oper   Port
                  Mode   Trunk                          Mode  Speed  Channel
                         Mode                                 (Gbps)
fc1/33     1      auto   on      sfpAbsent        --     --           --
fc1/34     1      auto   on      sfpAbsent        --     --           --
fc1/35     1      auto   on      sfpAbsent        --     --           --
fc1/36     1      auto   on      sfpAbsent        --     --           --
fc1/37     1      auto   on      sfpAbsent        --     --           --
fc1/38     1      auto   on      sfpAbsent        --     --           --
fc1/39     1      auto   on      up               swl    F       8    --
fc1/40     1      auto   on      sfpAbsent        --     --           --
fc1/41     1      auto   on      up               swl    F       8    --
fc1/42     1      auto   on      sfpAbsent        --     --           --
fc1/43     1      auto   on      sfpAbsent        --     --           --
fc1/44     1      auto   on      sfpAbsent        --     --           --
fc1/45     1      auto   on      sfpAbsent        --     --           --
fc1/46     1      auto   on      sfpAbsent        --     --           --
fc1/47     1      auto   on      sfpAbsent        --     --           --
fc1/48     1      auto   on      sfpAbsent        --     --           --
switch(config)# sh flogi database
INTERFACE        VSAN    FCID           PORT NAME               NODE NAME
fc1/39           1     0xe40041  50:05:07:68:0b:21:2f:33 50:05:07:68:0b:00:2f:33
fc1/41           1     0xe40080  21:00:00:0e:1e:cc:11:30 20:00:00:0e:1e:cc:11:30
Total number of flogi = 2.
switch(config)# sh zoneset active
zoneset name zoneset vsan 1
  zone name zone vsan 1
  * fcid 0xe40080 [pwwn 21:00:00:0e:1e:cc:11:30]
  * fcid 0xe40041 [pwwn 50:05:07:68:0b:21:2f:33]
switch(config)# sh vsan membership
vsan 1 interfaces:
    fc1/33            fc1/34            fc1/35            fc1/36
    fc1/37            fc1/38            fc1/39            fc1/40
    fc1/41            fc1/42            fc1/43            fc1/44
    fc1/45            fc1/46            fc1/47            fc1/48
vsan 4079(evfp_isolated_vsan) interfaces:
vsan 4094(isolated_vsan) interfaces:
switch(config)# sh license usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
FCOE_NPV_PKG                  Yes   -   Unused never       -
FM_SERVER_PKG                 No    -   Unused             -
ENTERPRISE_PKG                Yes   -   Unused never       -
FC_FEATURES_PKG               Yes   -   In use never       -
VMFEX_FEATURE_PKG             Yes   -   Unused never       -
ENHANCED_LAYER2_PKG           Yes   -   Unused never       -
NETWORK_SERVICES_PKG          No    -   Unused             -
LAN_BASE_SERVICES_PKG         Yes   -   In use never       -
LAN_ENTERPRISE_SERVICES_PKG   Yes   -   Unused never       -
marce1000
 - (Also) Check the logs when activating or trying to use an FC-port. check if anything comes up. Review current software version installed on the 5672 , use an advisory release :
           https://software.cisco.com/download/home/286221337/type/282088129/release/7.3(8)N1(1)
                                  Check if problems remain after that.
 M.
