Nexus 5k and Syslog output
sdawson35
Quick question around syslog output , we have 2 5k's (5548 ver 5.2(1)N1(4)) running in VSS mode (connected back to back via the management interfaces).
We are not getting any syslog output to our syslog server from either 5548.
Can anyone give me some help on what configuration is needed to achieve syslog output ?
We are not using loopback adapters and management of the 5k's is via a routable vlan.
Scott.
Furose M
Level 3
Level 3
have you configured syslog server in the switch?
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/system_management/502_n1_1/b_Cisco_n5k_system_mgmt_cg_rel_502_n1_1/Cisco_n5k_system_mgmt_cg_rel_502_n1_1_chapter9.html#task_5793349949823830091
Yes but we don't get any syslog output from the 2nd 5k , We are running 2 in a vss pairing.
So on SW1 we have
logging logfile messages 6
logging server 10.xx.x.xxx 6 use-vrf default
logging server 10.xx.x.xx 5 use-vrf default facility syslog
no logging monitor
logging level local7 6
no logging console
and SW2 we have
logging server 10.xx.x.xxx 7 use-vrf default
no logging monitor
no logging console
We get syslog to our syslog server from SW1 but never from SW2
eh 5ks don't do VSS do you mean VPC ? that should make no difference if there in VPC
have you tried reloading the effected 5k to clear any socket information
what does the show logging server provide
