nexus 5k with L3 card showed offline
alessandro.dona
Level 3
Level 3
Hi to all,
i have a nexus 5k with a l3 card i'm not able to bring online
NX-OS is:5.0(3)N2 (1)
L3 card is:L55D160L3
i inserted L3 module several time with the same resul...if i perform a show module i see the card offline.
At the boot switch show an error message:
L3 module is down due to a BTCM down...
Any of you can helP me?
is it a license issue?regards,
alessandro
8 Replies 8
Reza Sharifi
Layer 3 Base License
The Layer 3 base license (N55-BAS1K9) is included with the Cisco Nexus  5500 Platform switch. The license provides the following support:
Connected, Static, RIPv2, OSPF (256 Dynamically Learnt Routes), EIGRP-Stub, HSRP, VRRP, IGMPv2/3, PIMv2, RACLs, uRPF
Layer 3 LAN-Enterprise License
The Layer 3 LAN Enterprise license (N55-LAN1K9) includes the following:
All base license features
Full EIGRP
Unrestricted OSPF routes
BGP
VRF-Lite
Note The Layer 3 features require an installed Layer 3 Base license or LAN-Enterprise license.
For detailed information about the features that require licensing and Cisco NX-OS license installation, see the Cisco NX-OS Licensing Guide.
For information about troubleshooting licensing issues, see the Cisco Nexus 5000 Series NX-OS Troubleshooting Guide.
h
for more info:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/release/notes/Rel_5_0_3_N1_1/Nexus5000_Release_Notes_5_0_3_N1_1c.html#wp296235
So it would not seem to be a license issue
What does the log show when the module is inserted?
could i perform an hot swap?till now i always performed cold insert!
From what I can tell this is not true. We just installed 2 5548s with the L3 card and it did not come with the base license. We ordered the Enterprise license and installed it. As we were trying to setup HSRP it would not work. The primary 5548 would show itself as active with an unknown standby router. The secondary 5548 would show unknown for both active and standby router. We saw packet loss to the internet and were unable to ping the HSRP gateway. We called TAC and they gave us a base license and as soon as we installed it things work.
Are you sure the module is seated properly?
I do still have the same issue.
Ordered L3 Card with enterprise license but not the "included" base license.
Customers should now use cisco configurator when order a hardware module. The configurator tells you to order the "included" base license.
I also found bug id CSCtl45495 After the license has been reinstalled, the Layer 3 DC remains offline until the switch is rebooted.
But still have not tried the reload solution.
Got a limited lifetime base license from tech support, but L3 base license with time limit is not supported (showed up in the relese notes).
So as I got the time unlimited base license it works.
Hi to all,
i solved my issue by getting a license from licensing.com and loading it on nexus
thanks to all you!
regrads,
Alessandro
