Mac flapping between Lan and Wan interface
lnacional
Hi, i have a issue between two sites of  the company.
we have a main site (headquarters) and recently we connect a new site by a Lan to lan link. We trunk all vlans from main site to new site with a trunk port. And we having a problem with the clients of the new site, the mac address client flap between LAN ports (port-channels) and the wan port (gi 1/0/1).
attach diagrams.
logs:
I can't find any inconsistent configuration or loop that might be causing this behavior.
Thanks for you help
6 Replies 6
you config the L2VPN with VLAN 10,11,12,30
it seem that there is mismatch in native vlan between HQ and branch
so we need to make sure that both side use same native vlan
also please share the
show stp for both side if you can
lnacional
Hi! how are you?
Thanks for the response.
REmote site:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2023.05.22 16:40:23 =~=~=~=~=~=~=~=~=~=~=~=
login as: admin
Keyboard-interactive authentication prompts from server:
| Password:
End of keyboard-interactive prompts from server
SANTAFE_DC1-CORE#show spa
SANTAFE_DC1-CORE#show spanning-tree
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 24577
Address 0023.04ee.be64
Cost 5
Port 1 (GigabitEthernet1/0/1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 40961 (priority 40960 sys-id-ext 1)
Address f09e.6328.9700
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Po10 Desg FWD 4 128.528 P2p
Po11 Desg FWD 4 128.536 P2p
Po12 Desg FWD 4 128.544 P2p
Gi1/0/1 Root FWD 4 128.1 P2p
--More--
VLAN0007
Root ID Priority 32775
Cost 5
Bridge ID Priority 40967 (priority 40960 sys-id-ext 7)
Aging Time 300 sec
--More--
VLAN0008
Root ID Priority 32776
Address 0023.04ee.bec8
Cost 4
Bridge ID Priority 40968 (priority 40960 sys-id-ext 😎
Aging Time 300 sec
--More--
VLAN0010
Root ID Priority 24586
Cost 5
Bridge ID Priority 40970 (priority 40960 sys-id-ext 10)
Aging Time 300 sec
--More--
VLAN0011
Root ID Priority 24587
Cost 5
Bridge ID Priority 40971 (priority 40960 sys-id-ext 11)
Aging Time 300 sec
--More--
VLAN0012
Root ID Priority 24588
Cost 5
Bridge ID Priority 40972 (priority 40960 sys-id-ext 12)
Aging Time 300 sec
--More--
VLAN0015
Root ID Priority 32783
Cost 5
Bridge ID Priority 40975 (priority 40960 sys-id-ext 15)
Aging Time 300 sec
--More--
VLAN0016
Root ID Priority 40976
This bridge is the root
Bridge ID Priority 40976 (priority 40960 sys-id-ext 16)
Aging Time 300 sec
Gi1/0/1 Desg FWD 4 128.1 P2p
--More--
VLAN0020
Root ID Priority 24596
Cost 5
Bridge ID Priority 40980 (priority 40960 sys-id-ext 20)
Aging Time 300 sec
--More--
VLAN0024
Root ID Priority 32792
Cost 5
Bridge ID Priority 40984 (priority 40960 sys-id-ext 24)
Aging Time 300 sec
--More--
VLAN0030
Root ID Priority 24606
Cost 5
Bridge ID Priority 40990 (priority 40960 sys-id-ext 30)
Aging Time 300 sec
--More--
VLAN0050
Root ID Priority 24626
Cost 5
Bridge ID Priority 41010 (priority 40960 sys-id-ext 50)
Aging Time 300 sec
--More--
VLAN0051
Root ID Priority 32819
Cost 6
Bridge ID Priority 41011 (priority 40960 sys-id-ext 51)
Aging Time 300 sec
--More--
VLAN0100
Root ID Priority 24676
Cost 6
Bridge ID Priority 41060 (priority 40960 sys-id-ext 100)
Aging Time 300 sec
--More--
VLAN0204
Root ID Priority 32972
Cost 5
Bridge ID Priority 41164 (priority 40960 sys-id-ext 204)
Aging Time 300 sec
--More--
VLAN0234
Root ID Priority 33002
Cost 5
Bridge ID Priority 41194 (priority 40960 sys-id-ext 234)
Aging Time 300 sec
SANTAFE_DC1-CORE#                                 exit
HQ is attached in txt
Hello
Looks like you have a switching loop between Po11-po12-gig1/0/1, check the physical connections of the PCs for inconstancies (high utilisation, large stp transitions)  if possible disable a port within the PC to break the loop.
show interface | include line|\/sec
show spanning-tree interface detail | in transitions
Kind Regards
Paul
there is something in topology you share the HQ SW is vPC NSK and it connect to Branch via vPC  PO ?
if Yes can you re-draw the topology again
Hi, this is the core topology of HQ:
The Lan2Lan link is connected to CORE3 Switch.
you run MST in HQ and PVST in branch ?
