Nexus 7010 Radius Authentication Problem
Muhammad Ashfaq
Community Member
I am facing issue with nexus 7010 login authentcation by radius server. I have two nexus 7010, one of them is working perfectly. Other taking long time to authenticate. If i use local database to login it works perfectly. It works fine also  if i login from console using radius for authentication. Could you please shed some light on this issue why it is happening.
mahmoodmkl
Level 11
Level 11
Hi can u paste the aaa config and radius config section and verify u r sourcing this traffic from the management interface which is configred in acs
