04-23-2013 12:51 AM - edited 03-07-2019 12:58 PM
Hi everyone,
We switched the core devices from two cat 6500 to two nexus 7k and the most things work great but we got a strange problem with dhcp in combination with netflow. The Nexus 7k has a Sup2 and 3 x Fabric 2 Modules.
Mod Ports Module-Type Model Status
1 0 Supervisor module-2 N7K-SUP2 active *
3 48 1/10 Gbps Ethernet Module N7K-F248XP-25 ok
4 48 1/10 Gbps Ethernet Module N7K-F248XP-25 ok
Xbar Ports Module-Type Model Status
1 0 Fabric Module 2 N7K-C7009-FAB-2 ok
2 0 Fabric Module 2 N7K-C7009-FAB-2 ok
3 0 Fabric Module 2 N7K-C7009-FAB-2 ok
We currently use 2 VDCs on each of the two 7k, one is Layer3 only (Core) and the other is the Layer3/Layer2 boundry (Distribution), on the Core Layer3 only VDC Netflow works so far that it exports the flows, on the Distribution Layer3/Layer2 VDC we didnt manage that flows get exported.
Configuration Core:
flow exporter CA-NETFLOWCOLLECTOR
destination x.x.x.x
source loopback0
version 9
sampler PACKETWOLF
mode 1 out-of 100
flow monitor MONITOR-IPSS-TRAFFIC
record netflow-original
interface Ethernet3/2
ip flow monitor MONITOR-IPSS-TRAFFIC input sampler PACKETWOLF
Flow exporter CA-NETFLOWCOLLECTOR:
Description: export netflow to CA netflow appliance
Destination: x.x.x.x
VRF: default (1)
Source Interface loopback0 (x.x.x.x)
Export Version 9
Sequence number 1351870
Exporter Statistics
Number of Flow Records Exported 0
Number of Templates Exported 0
Number of Export Packets Sent 0
Number of Export Bytes Sent 0
Number of Destination Unreachable Events 0
Number of No Buffer Events 0
Number of Packets Dropped (No Route to Host) 0
Number of Packets Dropped (other) 0
Number of Packets Dropped (LC to RP Error) 0
Number of Packets Dropped (Output Drops) 0
Time statistics were last cleared: Tue Apr 23 09:37:08 2013
VRF: default (1)
Export Version 9
Exporter Statistics
Number of Flow Records Exported 9
Number of Templates Exported 1
Number of Export Packets Sent 2
Number of Export Bytes Sent 588
# show system internal access-list interface ethernet 3/2
slot 3
Policies in ingress direction:
Policy type Policy Id Policy name
Netflow Sampler 80000802
Netflow profiles in ingress direction:
TCAM Class Profile Flow Monitor
IPv4 2 MONITOR-IPSS-TRAFFIC
INSTANCE 0x0
Tcam 1 resource usage:
Label_b = 0x201
Bank 1
IPv4 Class
Policies: Netflow Sampler() [Merged]
Netflow profile: 0
Netflow deny profile: 0
1 tcam entries
0 l4 protocol cam entries
0 mac etype/proto cam entries
0 lous
0 tcp flags table entries
0 adjacency entries
No egress policies
Netflow profiles in egress direction:
slot 4
ERROR: no ACL related hardware resources for vdc [2], interface [Ethernet3/2]
Configuration Dist:
destination x.x.x.x
source loopback0
version 9
sampler PACKETWOLF
mode 1 out-of 100
flow monitor MONITOR-INTERVLAN-TRAFFIC
interface Vlan241
ip flow monitor MONITOR-INTERVLAN-TRAFFIC input sampler PACKETWOLF
ip dhcp relay address x.x.x.x
Here is the difference that we also use dhcp relay. If i remove the netflow statment on the interface and add it again i get the following error:
(config-if)# ip flow monitor MONITOR-INTERVLAN-TRAFFIC input sampler PACKETWOLF
An additional 1:100 sampler, over the configured sampler is applicable for F2 ports
Verify failed - Client 0x82000146, Reason: Tcam Allocation Failure, : DHCP, Netflow Sampler (SVI), Interface: Vlan241
Verify failed - Client 0x83000146, Reason: Tcam Allocation Failure, : DHCP, Netflow Sampler (SVI), Interface: Vlan241
Is there any limitation that i'm not aware of?
More output from the Dist:
VRF: default (1)
Export Version 9
Exporter Statistics
Time statistics were last cleared: Tue Apr 23 09:43:20 2013
show system internal access-list vlan 241
slot 3
DHCP 4 Relay
INSTANCE 0x8
Label_b = 0x201
Bank 0
IPv4 Class
Policies: DHCP(Relay) [Merged]
Netflow profile: 0
5 tcam entries
0 lous
1 adjacency entries
INSTANCE 0xa
Label_b = 0x201
Bank 0
IPv4 Class
Netflow profile: 0
5 tcam entries
0 lous
1 adjacency entries
INSTANCE 0xb
Label_b = 0x201
Bank 0
IPv4 Class
Netflow profile: 0
5 tcam entries
0 lous
1 adjacency entries
No egress policies
slot 4
DHCP 4 Relay
INSTANCE 0x8
Label_b = 0x201
Bank 0
IPv4 Class
Netflow profile: 0
5 tcam entries
0 lous
1 adjacency entries
No egress policies
Richard
04-25-2013 02:52 AM
Got the following answer from tac:
I did a bit of research & found that as of now netflow & dhcl relay is not supported together. This will be supported in 6.2
There is an enhancement bug already filed for the same. Bug id is CSCtf36357.
08-31-2014 02:06 PM
To Fix this.
we need 2 things
1) Code 6.2(6)
2) In default VDC, enable hardware access-list resource feature bank-mapping.
08-31-2014 11:46 PM
Thanks manaik, bank-mapping did the trick! In the default vdc configure: "hardware access-list resource feature bank-mapping" and then I was able to have netflow and dhcp relay on the same interface.
I found another thread on the subject as well: https://supportforums.cisco.com/discussion/12075471/nexus-7k-dhcp-relay-w-ingress-netflow-sampling
Again, thanks alot!
09-01-2013 02:24 PM
01-07-2014 02:43 AM
I just noticed the changes from yesterday 6 Jan 2014.
It seems that this bug has been fixed in NXOS 6.2(2).
Is there a chance that the bug will be fixed in the 6.1.(x) train aswell?
01-25-2014 11:08 PM
We are experiencing this issue on our Nexus 7K's and we are running NX-OS 6.2(2a). Does not look like this is fixed yet.
01-26-2014 12:15 PM
Hi Guys,
The fix was planned originally for 6.2.2 but was pushed to 6.2.6 due some other priorities. This has been fixed in 6.2.6.
Please see the release notes.
Cheers,
-amit singh
01-29-2014 11:43 AM
Just removed the DHCP relays from my interface Vlan and was able to add the ip flow monitor with no issue. Tried adding the dhcp relays back and recevied:
ERROR: Hardware programming failed. Reason: Tcam Allocation Failure
Removed the ip flow monitor and was able to add back the dhcp relays. Looks like it is not fixed yet. I am at 6.2.6.
02-19-2014 06:05 AM
Just to confirm, upgraded to 6.2.6 to get around having to add the hardware ACL. The ACL was still required after the upgrade.
If this posts answers your question or is helpful, please consider rating it and/or marking as answered.
08-31-2014 11:48 PM
This seems to still be a problem. We currently on Nexus 7704 chassi with N77-F348XP-23 with NX-OS version 6.2(8). When will this be fixed?
Edit: This is not a bug, you just need to configure "hardware access-list resource feature bank-mapping"
03-21-2018 09:57 AM
Sorry for bother you, but do you I'm having the same problem on Nexus 7706 after migration form Cisco C6509. I want to allow DHCP relay and netflow on the same interface. If I run this command "(config)# hardware access-list resource feature bank-mapping". Does it impact the network in some way?
