11-21-2012 09:52 PM - edited 03-07-2019 10:11 AM
Hi All,
Please give ur inputs on these
Nexus Core switch 7K Gives arp request for his own Local IP address continuously. This Logs keeps on coming for the past 2 months.
The Ip Address 10.80.18.1 is an secondary IP address of vlan 18 , which is used for Teleprescence. Please find the Interface Configs and Logs attached
interface Vlan18
no shutdown
no ip redirects
ip address 10.80.18.252/24
hsrp version 2
hsrp 18
preempt
priority 110
timers 1 3
ip 10.80.18.1 secondary
ip 10.80.18.254
2012 Nov 12 18:22:06 FRMA_BK1_CSN7K_01-COR %ARP-3-REQ_IP: arp [3829] Sending A
RP request for local IP address 10.80.18.1 on Vlan18, request from pid: 3834
2012 Nov 12 18:22:07 FRMA_BK1_CSN7K_01-COR %ARP-3-INVAL_HDR: arp [3829] Found
incorrect hardware/protocol type in ARP header: 6/2048
2012 Nov 12 18:22:53 FRMA_BK1_CSN7K_01-COR last message repeated 2 times
Solved! Go to Solution.
11-26-2012 06:11 PM
Please check your routing table and see if this ip address 10.80.18.1 is appearing in any static route as a next hop. That would be your problem.
Nik
11-26-2012 06:11 PM
Nik
10-04-2015 02:50 AM
thanx. Resolved my issue too :D
06-30-2017 12:59 PM
Also helped me - middle of the night!
Thanks!
