07-01-2022 11:51 AM
Hello Experts,
I am using NX9K version 9.3(3), and I want to enable IGMP querier for L2 multicast, but I can't find the command,
please see the attached picture and kindly advise!
Solved! Go to Solution.
07-01-2022 12:23 PM
According to the guide you are not configuring it correctly.
You are in interface mode but you should be in vlan configuration mode ie.
switch(config)# vlan configuration <vlan ID>
switch(config-vlan-config)# ip igmp snooping
switch(config-vlan-config)# ip igmp querier <IP address>
Jon
07-01-2022 12:28 PM
Under vlan configuration:
(config-vlan-config)# ip igmp snooping querier
07-01-2022 12:04 PM
hi,
Have a look at the config guide on how to configure it.
07-01-2022 12:09 PM
I know the guide , but I can’t see the command under the vlan configuration , as mentioned in the attached picture.
07-01-2022 12:23 PM
Jon
07-01-2022 12:28 PM
07-01-2022 09:19 PM
finally there, thank you very much, everyone .
