Nexus_DHCP_device can not gain IP address
incognito
hello, friends
I need a help. For more info open an attached image, please.
1. I installed DHCP Server on Windows server 2012. Created 8 dhcp scopes for 8 subnets.
2. I configured DHCP relay on Nexus 6000. (configuration file is attached)
3. I configured C3560 switch to connect user devices, as you know on Nexus all ports are SFP, that's why I use this switch to connect user devices to the nexus. (configuration file of C3560 is attached)
4. The interface fastethernet0/2 on C3560 I configured as switchport mode access and the port belongs to vlan 402. Then I
connected my laptop to this port, but I couldn't get any IP-address from this scope (dhcp-address-range 10.111.3.6 - 10.111.3.254)
That is my problem. Any advice would be helpful
23 Replies 23
Hi incognito!
looks simple enough, and the diagrams make it really clear so thanks for uploading those!
basically you’ve done later 2 and 3 segregation but you haven’t told the switch where to forward DHCP requests.
Before doing any programming, verify you can ping the dhcp server from the 3650 switch. If so, continue ahead.
Youll need to set the “helper address” to tel the switch where to forward dhcp requests to. Log into the switch and do as follows:
(config)#int VLAN 402
(config-int)#ip helper-address (10.100.0.18)
exit
exit
write
I would recommend doing this on a per-VLAN basis (so it sounds like 8 times?), although if I remember correctly Cisco recommends you do this at the global config level (setting the helper address for the entire switch rather than per VLAN).
Hope this helps!
Please remember to rate and mark as solved if this fixes the issue!
-Zac
Thanks for the answer
Ok I will check/config.
What else would be a reason of a problem
It is possible that your relay (the nexus) is dropping the DHCP packets from the switch. I’m not sure what the default feature are for that nexus but if your ip helper command is programmed into your access switch and you can ping try one of the following two commands on the nexus:
(Config) ip dhcp relay information policy keep
OR
Navigate to the trunk link between interfaces on the nexus and
(config-If) ip dhcp relay information trusted
both of these commands effectively tell your nexus switch to not replace any dhcp information that it receives from the access switch 3650.
Please rate/mark if this is useful.
-Zac
balaji.bandi
From 3560, check you have reachability for your DHCP server, Once that is confirmed
interface Vlan402
ip address 10.111.3.1 255.255.255.0
ip helper-address 10.100.0.18
BB
ok I will check it all
What else can be the reason of this problem? Do I need some configurations on DHCP server (Windows server 2012)??
On DHCP Server there is no modification required, changes required on the VLAN on the Core side
as I have suggested other post make sure you able to ping the IP address of the DHCP Server before proceeding further.
adding the same comment as paul suggested configure static IP and test for the same port and see you able to ping GW IP.
BB
Hello
As the Nxos core is performing the L3 routing suggest apply the helper address on it L3 interface for that vlan
int vlan xx
ip dhcp relay address x.x.x.x
Kind Regards
Paul
Hello, Paul
i have configured it already. From config file of nexus:
Nexus-6001# show ip dhcp relay address
 Interface        Relay Address     VRF Name
 Vlan402           10.100.0.18
Hello
Can you ping the dhcp server from the core switch sourced from that vlan?
Do your switches have a l2 vlan created for that vlan, it should have been created automatically on the L2 switch when you assigned an access port to it but check anyway on all switches
sh vlan brief
Also as a test if you manually apply addressing ( ip address/subnetmask/default-gateway) to an host connected to that switch does have reachability to the network?
Kind Regards
Paul
Thanks, Paul
I will check!
hello
- yes
Nexus-6001# ping 10.100.0.18 source 10.111.3.1
PING 10.100.0.18 (10.100.0.18) from 10.111.3.1: 56 data bytes
64 bytes from 10.100.0.18: icmp_seq=0 ttl=127 time=0.853 ms
64 bytes from 10.100.0.18: icmp_seq=1 ttl=127 time=0.714 ms
64 bytes from 10.100.0.18: icmp_seq=2 ttl=127 time=0.619 ms
64 bytes from 10.100.0.18: icmp_seq=3 ttl=127 time=0.625 ms
64 bytes from 10.100.0.18: icmp_seq=4 ttl=127 time=0.603 ms
sh vlan brief
-yes.
3560#sh vlan brief
VLAN Name Status Ports
1 default active Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/7, Fa0/8
90 VLAN0090 active
99 Fortigate active
100 Servers active
120 VLAN0120 active
199 AP active
201 Switches active
288 BMS2 active
289 BMS active
290 cinema active
295 Equipment active
298 Ekran active
299 Sound active
300 Service_Data active
301 Service_WiFi active
302 Service_Voice active
400 Office_Data active
401 Office_WiFi active
402 Office_Voice active                          Fa0/2
500 Video active
501 Temporary active
510 Security active
511 Security_Data active
512 Security_Voice active
606 Wireless active
860 test active
- yes.
C:\Users\user> ping 10.100.0.18
Pinging 10.100.0.18 with 32 bytes of data:
Reply from 10.100.0.18: bytes=32 time<1ms TTL=127
Reply from 10.100.0.18: bytes=32 time=1ms TTL=127
Reply from 10.100.0.18: bytes=32 time=8ms TTL=127
on nexus i configured this one:
interface Vlan402
ip dhcp relay address 10.100.0.18  (not this one: ip helper-address 10.100.0.18)
Do I need some configuration on DHCP server, or some commands on nexus (may be I have to configure interfaces like trusted or stuff like that)...?
zachrhart@gmail.com
@balaji.bandi
on quick high level I have noticed that you have configured both switch interface VLAN 402 with IP address.
Nexus :
interface Vlan402
description Main_Office(17)_Voice
ip address 10.111.3.1/24
3560
interface Vlan402
As per my understanding, you want to extend the VLAN to 3650 and user device connected should get IP address from DHCP.
in this case, remove interface VLAN 402 from 3650. - this no makes any sense ( you can have IP address if you like not the same IP address on both the switches.)
to remidiate for testing :
Go to 3650
config t
no interface Vlan402
end
Connect the PC to
interface FastEthernet0/2
switchport access vlan 402
test and advise.
BB
Yes you’re right. It was a mistake. I already deleted this vlan interfaces from c3560.
I cant realize what would be reason of problem
Hello
Thank you for you posts  --
After reviewing your configuration again you don't need ip routing enabled on your 3560 switch in fact you dont require any of those L3 interfaces apart from fa0/1for mgt reach-ability as the nxos is performing the inter-vlan routing
3560 switch
could you try disabling no ip routing thus making that switch a host switch and see if you are then able to obtain dhcp allocation
conf t
no ip routing
ip default-gateway 192.168.210.1
Kind Regards
Paul
