Nexus OSPF
Hi, i am new in nexus and need some help in OSPF
i have nexus connected to another router and the interfaces are trunk between them, i am forming the ospf between vlan5 in each router there is interface vlan 5 and ip x.x.x.1 and x.x.x.2 in the other router
ihave many vlans in that range10.153.x.x/16
how i can advertise 10.153.x.x/16 in ospf nexus 7K ? should i enable ospf on each vlan in that range?
Hello
Yes please review the example above, I believing its the correct config for a NX-OS switch regards OSPF
Kind Regards
Paul
7 Replies 7
Hello
Specify the ip address of the vlan you which to ospf peer with and advertise from within that interface
example:
10.10.10.1 is in vlan 10 - advertise and form an adjacency
10.150.0.1/16  vlan 150  —-advertise but not to form any adjacency
10.153.0.0/16 encompass 50 other vlans —-like to advertise as a whole
feature ospf
Router ospf 1
area 0 range 10.153.0.0/16
Interface vlan 10
ip address 10.10.10.1 255.255.255.252
ip router ospf 1 area 0
interface vlan 150
ip address 10.150.0.1 255.255.0.0
ip ospf 1 passive interface default
Kind Regards
Paul
Hi Paul,
so if i enabled the ospf on the vlan connecting the 2 routers, that will enable the hall range ?10.153.0.0/16?
so if i have 10 vlans start with 10.153.x.x i don't have to enable ospf on each of them?
Hello
if you enable ospf on one specific vlan then it will advertise its whole subnet it attached to into ospf and will try to establish an adjeceny to any other ospf enabled interface in that subnet however you can also advertise the rest of your vlans in ospf withouthaving those vlans also try to establish a peering session
The passive interface default command negates any routing update be sent or received to all interfaces unless you specify the no passive interface which will then allow these updates and neighbourship to be established in that specific interface
Kind Regards
Paul
Paul, could you please give me configuration example for ospf in nexus 7k
thanks
I think he has already provided the example in his earlier post
Hello
Kind Regards
Paul
Thank Paul
