Nexus Switch 93128TX Booting Issue
wajid_dabir
I am getting below error after powering ON the switch. I have also attached the logs file for complete logs review.
CISCO SWITCH Ver7.17
Device detected on 0:6:0 after 0 msecs
Device detected on 0:1:1 after 0 msecs
Device detected on 0:1:0 after 0 msecs
ERROR: Memory init failed!
: PostCode 0x41
: PostCode 0x41
: PostCode 0x41
: PostCode 0x41
: PostCode 0x41
: PostCode 0x41
: PostCode 0x41
: PostCode 0x41
: PostCode 0x41
: PostCode 0x41
: PostCode 0x41
Could someone please advise on fixing this issue.
Wajid Dabir
marce1000
  - Looks like a fatal hardware problem , issue power cycle, if that does not help , contact TAC and or confirm that the device needs to be replaced (RMA).
 M.
marce1000
 M.
wajid_dabir
Yeah, It was an hardware issue only. Hence generate the RMA.
ahmed-mujeeb
just open the switch and check the RAM, either one of the two RAM are not functioning. Secondly just remove the RAM and use any low pressure air blower to remove the dust in the slots and also clean the RAM, then install them and surely it will work.
Ahmed Mujeeb
