Nexus vPC help (GNS3 lab)
Andrew White
Level 2
Level 2
We use Nexus 3Ks as our core switches and I've been trying to build these in GNS3 as I need to make some changes on the live switches soon and want to test few things in a lab environment.
I've put most of the config on the 2 switches, but I'm hitting issues with the vPC on ports Eth1/8 (keep alive) and Eth 1/9 (port channel).
The keep alive seems ok as they can ping each other.  However on the Nexus 2 switch I eventually get a BPDU guard alerts due to looks and it shuts the ports down and in some cases reboots the switch (GNS2 possibly).
Can you see anything wrong?
Nexus 1
interface Ethernet1/8
  description vPC KeepAlive
  no switchport
  vrf member vPC-Keepalive
  ip address 172.31.255.253/30
  no shutdown
TEST-LH-LAN-NEXUS-01# sh run int eth1/9
!Command: show running-config interface Ethernet1/9
!Time: Thu May 23 10:28:45 2019
version 7.0(3)I7(3)
  description EMG-LH-LAN-NEXUS vPC
  switchport mode trunk
  spanning-tree port type network
  channel-group 4096
Nexus 2
  no switchport
  ip address 172.31.255.254/30
  no shutdown
  channel-group 4096
From Nexus 1
TEST-LH-LAN-NEXUS-01# sh vpc peer-keepalive
vPC keep-alive status             : peer is alive
--Peer is alive for             : (159) seconds, (575) msec
--Send status                   : Success
--Last send at                  : 2019.05.23 10:32:34 267 ms
--Sent on interface             : Eth1/8
--Receive status                : Success
--Last receive at               : 2019.05.23 10:32:34 3 ms
--Received on interface         : Eth1/8
--Last update from peer         : (0) seconds, (342) msec
vPC Keep-alive parameters
--Destination                   : 172.31.255.254
--Keepalive interval            : 1000 msec
--Keepalive timeout             : 5 seconds
--Keepalive hold timeout        : 3 seconds
--Keepalive vrf                 : vPC-Keepalive
--Keepalive udp port            : 3200
--Keepalive tos                 : 192
From Nexus 2
Test-LH-LAN-NEXUS-02# show vpc peer-keepalive
--Peer is alive for             : (231) seconds, (440) msec
--Last send at                  : 2019.05.23 10:33:46 928 ms
--Last receive at               : 2019.05.23 10:33:46 493 ms
--Last update from peer         : (1) seconds, (0) msec
--Destination                   : 172.31.255.253
Nexus 1
TEST-LH-LAN-NEXUS-01# sh vpc bri
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 990
Peer status                       : peer adjacency formed ok
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary
Number of vPCs configured         : 5
Peer Gateway                      : Enabled
Dual-active excluded VLANs        : 254
Graceful Consistency Check        : Enabled
Auto-recovery status              : Disabled
Delay-restore status              : Timer is off.(timeout = 60s)
Delay-restore SVI status          : Timer is off.(timeout = 5s)
Operational Layer3 Peer-router    : Disabled
vPC Peer-link status
id    Port   Status Active vlans
1     Po4096 up     1,10,20-22,30,40,70-72,80,90,99-100,110,120,130,1
                    40,142,150,160,200,202,204,206,208,210,254,300,91
                    1,990,998-999
vPC status
Id    Port          Status Consistency Reason                Active vlans
10    Po10          down*  Not         Consistency Check Not -
                           Applicable   Performed
11    Po11          down*  Not         Consistency Check Not -
14    Po14          down*  Not         Consistency Check Not -
20    Po20          down*  Not         Consistency Check Not -
21    Po21          down*  Not         Consistency Check Not -
Please check "show vpc consistency-parameters vpc <vpc-num>" for the
consistency reason of down vpc and for type-2 consistency reasons for
any vpc.
Nexus 2
Test-LH-LAN-NEXUS-02# sh vpc bri
Legend:
vPC domain id                     : 990
Peer status                       : peer link is down
Configuration consistency status  : failed
Configuration inconsistency reason: Consistency Check Not Performed
Type-2 inconsistency reason       : Consistency Check Not Performed
vPC role                          : none established
Graceful Consistency Check        : Disabled (due to peer configuration)
1     Po4096 up     -
vPC status
10    Po10          down   Not         Consistency Check Not -
11    Po11          down   Not         Consistency Check Not -
14    Po14          down   Not         Consistency Check Not -
20    Po20          down   Not         Consistency Check Not -
21    Po21          down   Not         Consistency Check Not -
any vpc.
Can ping across
TEST-LH-LAN-NEXUS-01# ping 172.31.255.254 source-interface eth 1/8
PING 172.31.255.254 (172.31.255.254): 56 data bytes
64 bytes from 172.31.255.254: icmp_seq=0 ttl=254 time=32.194 ms
64 bytes from 172.31.255.254: icmp_seq=1 ttl=254 time=12.565 ms
64 bytes from 172.31.255.254: icmp_seq=2 ttl=254 time=6.27 ms
64 bytes from 172.31.255.254: icmp_seq=3 ttl=254 time=22.06 ms
64 bytes from 172.31.255.254: icmp_seq=4 ttl=254 time=41.795 ms
What will happen is eventually I will get some loop issues kick in.
Does above look ok and healthy as I'm not sure how you test this.
I'm use to stacking switches and not vPC setups, I thinks it's just a big trunk?
7 Replies 7
Mark Malone
wheres the PO config is it set for VPC at the end ?
Have you completed the global VPC config with domains ?
Your config looks ok we do it slightly different at the heartbeat or keepalive with a L3 SVI routed and assign it to the port like below
interface Vlan3000
description VPC Heartbeat
vrf member heartbeat
ip address x.x.x.x
interface Ethernet1/44
switchport access vlan 3000
logging event port link-status
VPC link example
interface port-channel2
description
no lacp suspend-individual
switchport trunk allowed vlan 2,10-11,17-18,20,28,31,33-34,36-39,48,50,64-65,70,72,74,76,78,80,90-96,102-108,226,400,1226,2224,2512,3020,3025-3028
logging event port trunk-status
speed 10000
vpc 2
description
speed 10000
vpc 2
Global each switch
vpc domain 200
role priority 200
system-priority 150
peer-keepalive destination x.x.x.x source x.x.x.x delay restore 90
Other side would be a reverse with priority 150
Sorry I missed some bits here:
Nexus 1
vrf context management
vrf context vPC-Keepalive
no system urpf disable
hardware profile portmode 48X10G+breakout6x40g
vpc domain 990
  peer-switch
  role priority 8192
  system-priority 8192
  peer-keepalive destination 172.31.255.254 source 172.31.255.253 vrf vPC-Keepal
ive
  delay restore 60
  dual-active exclude interface-vlan 254
  peer-gateway
  delay restore interface-vlan 5
  ip arp synchronize
Nexus 2
vpc domain 990
  peer-switch
  role priority 16384
  peer-keepalive destination 172.31.255.253 source 172.31.255.254 vrf vPC-Keepalive
  delay restore 60
  peer-gateway
  ip arp synchronize
interface port-channel4096
vpc peer-link
I will add the other port channels to the switch configs, but does the VPC number have to match the port channel number or is it best practice?
No they dont need to match but from deploying these setups it does make it easier to manage for yourself when it matches moving forward but not essential to operation , your config looks right you might be hitting some emulator issue in GNS3 , ive never ran these on GNS only on VIRL , which does work but even that issues at times
These 2 outputs are obviously an issue , did you try set the channel-group to LACP , channel-group 4096 mode active - each side , again could be GNS3 though , thats only diff i can see against my working 7ks , that its not ;LACP on the VPC peer link members
Try this command too as the consistency check is saying there is miss matches in config somewhere too
show vpc consistency-parameters interface po4096
Symptom Possible Cause Solution
Received a type 1 configuration element mismatch. The vPC peer ports or membership ports do not have identical configurations. Use the show vpc consistency-parameters interface command to determine where the configuration mismatch occurs.
Thanks guys, I will try all this when I get back to work tomorrow and let you know. It’s on a VM with 32GB men as I can’t run these switches on my laptop :)
mohammed01701
Hi!
Could you please send the full config on both switches?
I think you do have some problem on the second switch!
/Mohammed
Just to add, I would echo that it could be the emulating features in GNS3, I have had it working before but there are some oddities that can occur.
