Nexus vPC orphan ports
bryantsteve
We have a topology using two nk5 switches with  vPC  configured and  each with a FEX  module attached. On these FEX modules  we have  devices  having  a single connection to a port on one FEX but find it necessary to configure the corresponding  port on the second FEX (non connected) in order to make the connected port active,  How do we configure the switches without duplicating the port configuration on an unused port?
7 Replies 7
Reza Sharifi
If the FEX is connected to both nk5 switches, you need to configure the same exact port and config on both switches in order for the port on the FEX to come up.
Hi Reza
No the FEX modules are connected to one, not both nk5 switches
If the FEX is connected to only one switch then you can configure that one switch and it should work.
Can you post the config and the error message?
balaji.bandi
Is this FEX are singled homed or dual Homed ?
If singled Homed then you going to configure only  respected to Parent 5K only
If dual homed, you need to configure both 5K same configuration ( if you have not sync  configruation automatically).
BB
The FEXs are single homed. There is an air gap between these production switches and my email service so posting configs or logs is challenging  but I  notice logging stating  the offending VLAN  is in error state because the VLAN is not allowed on peer-link (the FEX port is access mode no port channel). There is no VLAN  filtering configured on the peer-link
Can you make sure that the vlan is part of the peer-link?
Make sure the VLAN present in the peer link, atleast you can post that particular log.
BB
