nhrp or eigrp flapping - dmvpn
tbsavcenter
Community Member
Hello everybody
i am relative new to the cisco ios, so go easy on me i have some strange problems with our dmvpn setup. it is a single hub to multiple spoke setup.
The eigrp routes comes and goes. the tunnel is up when i do "show dmvpn"
Here is the debug log with eigrp packets and nhrp packets
Jan 17 10:59:01.380: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 6C 00 34
Jan 17 10:59:01.788: EIGRP: Sending TIDLIST on Tunnel1 - 1 items0
Jan 17 10:59:01.788: EIGRP: Sending HELLO on Tu1 - paklen 30
Jan 17 10:59:01.788:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
Jan 17 10:59:02.358: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.10
Jan 17 10:59:02.358:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:02.409: EIGRP: Sending UPDATE on Tu1 - paklen 0 nbr 192.168.0.10, retry 2, RTO 4500 tid 0
Jan 17 10:59:02.409:   AS 90, Flags 0x1:(INIT), Seq 131/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:03.946: NHRP: Receive Registration Request via Tunnel1 vrf global(0x0), packet size: 108
Jan 17 10:59:03.947:  (F) afn: AF_IP(1), type: IP(800), hop: 255, ver: 1
Jan 17 10:59:03.947:      shtl: 4(NSAP), sstl: 0(NSAP)
Jan 17 10:59:03.947:      pktsz: 108 extoff: 52
Jan 17 10:59:03.947:  (M) flags: "unique nat ", reqid: 230
Jan 17 10:59:03.947:      src NBMA: 172.20.1.49
Jan 17 10:59:03.947:      src protocol: 192.168.0.10, dst protocol: 192.168.0.254
Jan 17 10:59:03.947:  (C-1) code: no error(0)
Jan 17 10:59:03.947:        prefix: 32, mtu: 17870, hd_time: 60
Jan 17 10:59:03.947:        addr_len: 0(NSAP), subaddr_len: 0(NSAP), proto_len: 0, pref: 0
Jan 17 10:59:03.947: NHRP: Send Registration Reply via Tunnel1 vrf global(0x0), packet size: 148
Jan 17 10:59:03.947:  src: 192.168.0.254, dst: 192.168.0.10
Jan 17 10:59:03.947:      pktsz: 148 extoff: 52
Jan 17 10:59:03.952: NHRP: Receive Registration Reply via Tunnel1 vrf global(0x0), packet size: 168
Jan 17 10:59:03.953:  (F) afn: AF_IP(1), type: IP(800), hop: 254, ver: 1
Jan 17 10:59:03.953:      shtl: 4(NSAP), sstl: 0(NSAP)
Jan 17 10:59:03.953:      pktsz: 168 extoff: 52
Jan 17 10:59:03.953:  (M) flags: "unique nat ", reqid: 230
Jan 17 10:59:03.953:      src NBMA: 172.20.1.49
Jan 17 10:59:03.953:      src protocol: 192.168.0.10, dst protocol: 192.168.0.254
Jan 17 10:59:03.953:  (C-1) code: no error(0)
Jan 17 10:59:03.953:        prefix: 32, mtu: 17870, hd_time: 60
Jan 17 10:59:03.953:        addr_len: 0(NSAP), subaddr_len: 0(NSAP), proto_len: 0, pref: 0
Jan 17 10:59:03.953: NHRP: Forwarding Registration Reply via Tunnel1 vrf global(0x0), packet size: 188
Jan 17 10:59:03.953:  src: 192.168.0.254, dst: 192.168.0.10
Jan 17 10:59:03.953:  (F) afn: AF_IP(1), type: IP(800), hop: 253, ver: 1
Jan 17 10:59:03.953:      pktsz: 188 extoff: 52
Jan 17 10:59:03.960: NHRP: Receive Error Indication via Tunnel1 vrf global(0x0), packet size: 228
Jan 17 10:59:03.960:  (F) afn: AF_IP(1), type: IP(800), hop: 255, ver: 1
Jan 17 10:59:03.960:      shtl: 4(NSAP), sstl: 0(NSAP)
Jan 17 10:59:03.960:      pktsz: 228 extoff: 0
Jan 17 10:59:03.960:  (M) error code: loop detected(3), offset: 84
Jan 17 10:59:03.960:      src NBMA: 172.20.2.85
Jan 17 10:59:03.960:      src protocol: 192.168.0.11, dst protocol: 192.168.0.254
Jan 17 10:59:03.960:      Contents of error packet:
Jan 17 10:59:03.960:         00 01 08 00 00 00 00 00 00 FD 00 BC 84 69 00 34
Jan 17 10:59:03.960:         01 04 04 00 04 04 80 02 00 00 00 E6 AC 14 01 31
Jan 17 10:59:03.960:         C0 A8 00 0A C0 A8 00 FE
Jan 17 10:59:04.622: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.11
Jan 17 10:59:04.623:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
Jan 17 10:59:06.478: EIGRP: Sending TIDLIST on Tunnel1 - 1 items0
Jan 17 10:59:06.478: EIGRP: Sending HELLO on Tu1 - paklen 30
Jan 17 10:59:06.478:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
Jan 17 10:59:06.909: EIGRP: Sending UPDATE on Tu1 - paklen 0 nbr 192.168.0.10, retry 3, RTO 5000 tid 0
Jan 17 10:59:06.909:   AS 90, Flags 0x1:(INIT), Seq 131/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:07.062: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.10
Jan 17 10:59:07.063:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:09.366: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.11
Jan 17 10:59:09.367:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
Jan 17 10:59:10.810: NHRP: Receive Registration Request via Tunnel1 vrf global(0x0), packet size: 108
Jan 17 10:59:10.810:  (F) afn: AF_IP(1), type: IP(800), hop: 255, ver: 1
Jan 17 10:59:10.811:      shtl: 4(NSAP), sstl: 0(NSAP)
Jan 17 10:59:10.811:      pktsz: 108 extoff: 52
Jan 17 10:59:10.811:  (M) flags: "unique nat ", reqid: 1761
Jan 17 10:59:10.811:      src NBMA: 192.168.2.50
Jan 17 10:59:10.811:      src protocol: 192.168.0.13, dst protocol: 192.168.0.254
Jan 17 10:59:10.811:  (C-1) code: no error(0)
Jan 17 10:59:10.811:        prefix: 32, mtu: 17870, hd_time: 60
Jan 17 10:59:10.811:        addr_len: 0(NSAP), subaddr_len: 0(NSAP), proto_len: 0, pref: 0
Jan 17 10:59:10.811: NHRP: Send Registration Reply via Tunnel1 vrf global(0x0), packet size: 148
Jan 17 10:59:10.811:  src: 192.168.0.254, dst: 192.168.0.13
Jan 17 10:59:10.811:  (F) afn: AF_IP(1), type: IP(800), hop: 255, ver: 1
Jan 17 10:59:10.811:      pktsz: 148 extoff: 52
Jan 17 10:59:10.913: EIGRP: Sending TIDLIST on Tunnel1 - 1 items0
Jan 17 10:59:10.913: EIGRP: Sending HELLO on Tu1 - paklen 30
Jan 17 10:59:10.913:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
Jan 17 10:59:11.909: EIGRP: Sending UPDATE on Tu1 - paklen 0 nbr 192.168.0.10, retry 4, RTO 5000 tid 0
Jan 17 10:59:11.909:   AS 90, Flags 0x1:(INIT), Seq 131/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:12.054: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.10
Jan 17 10:59:12.055:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:13.647: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.11
Jan 17 10:59:13.647:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
Jan 17 10:59:15.453: EIGRP: Sending TIDLIST on Tunnel1 - 1 items0
Jan 17 10:59:15.453: EIGRP: Sending HELLO on Tu1 - paklen 30
Jan 17 10:59:15.454:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
Jan 17 10:59:16.284: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.10
Jan 17 10:59:16.284:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:16.910: EIGRP: Sending UPDATE on Tu1 - paklen 0 nbr 192.168.0.10, retry 5, RTO 5000 tid 0
Jan 17 10:59:16.910:   AS 90, Flags 0x1:(INIT), Seq 131/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:18.152: NHRP: Receive Registration Request via Tunnel1 vrf global(0x0), packet size: 108
Jan 17 10:59:18.153:  (F) afn: AF_IP(1), type: IP(800), hop: 255, ver: 1
Jan 17 10:59:18.153:      shtl: 4(NSAP), sstl: 0(NSAP)
Jan 17 10:59:18.153:      pktsz: 108 extoff: 52
Jan 17 10:59:18.153:  (M) flags: "unique nat ", reqid: 1565
Jan 17 10:59:18.153:      src NBMA: 172.20.2.85
Jan 17 10:59:18.153:      src protocol: 192.168.0.11, dst protocol: 192.168.0.254
Jan 17 10:59:18.153:  (C-1) code: no error(0)
Jan 17 10:59:18.153:        prefix: 32, mtu: 17870, hd_time: 60
Jan 17 10:59:18.153:        addr_len: 0(NSAP), subaddr_len: 0(NSAP), proto_len: 0, pref: 0
Jan 17 10:59:18.153: NHRP: Send Registration Reply via Tunnel1 vrf global(0x0), packet size: 148
Jan 17 10:59:18.153:  src: 192.168.0.254, dst: 192.168.0.11
Jan 17 10:59:18.153:      pktsz: 148 extoff: 52
Jan 17 10:59:18.452: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.11
Jan 17 10:59:18.453:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
Jan 17 10:59:20.366: EIGRP: Sending HELLO on Tu1 - paklen 20
Jan 17 10:59:20.366:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
Jan 17 10:59:20.747: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.10
Jan 17 10:59:20.747:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:21.405: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.13
Jan 17 10:59:21.405:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
Jan 17 10:59:21.911: EIGRP: Sending UPDATE on Tu1 - paklen 0 nbr 192.168.0.10, retry 6, RTO 5000 tid 0
Jan 17 10:59:21.911:   AS 90, Flags 0x1:(INIT), Seq 131/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:23.453: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.11
Jan 17 10:59:23.453:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
Jan 17 10:59:24.996: EIGRP: Sending HELLO on Tu1 - paklen 20
Jan 17 10:59:24.996:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
Jan 17 10:59:25.134: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.10
Jan 17 10:59:25.134:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:26.911: EIGRP: Sending UPDATE on Tu1 - paklen 0 nbr 192.168.0.10, retry 7, RTO 5000 tid 0
Jan 17 10:59:26.911:   AS 90, Flags 0x1:(INIT), Seq 131/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:28.147: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.11
Jan 17 10:59:28.147:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
Jan 17 10:59:29.711: EIGRP: Sending HELLO on Tu1 - paklen 20
Jan 17 10:59:29.711:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
Jan 17 10:59:29.959: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.10
Jan 17 10:59:29.960:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:31.912: EIGRP: Sending UPDATE on Tu1 - paklen 0 nbr 192.168.0.10, retry 8, RTO 5000 tid 0
Jan 17 10:59:31.913:   AS 90, Flags 0x1:(INIT), Seq 131/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:33.031: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.11
Jan 17 10:59:33.032:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
Jan 17 10:59:33.952: NHRP: Receive Registration Request via Tunnel1 vrf global(0x0), packet size: 108
Jan 17 10:59:33.952:  (F) afn: AF_IP(1), type: IP(800), hop: 255, ver: 1
Jan 17 10:59:33.952:      shtl: 4(NSAP), sstl: 0(NSAP)
Jan 17 10:59:33.952:      pktsz: 108 extoff: 52
Jan 17 10:59:33.952:  (M) flags: "unique nat ", reqid: 231
Jan 17 10:59:33.952:      src NBMA: 172.20.1.49
Jan 17 10:59:33.952:      src protocol: 192.168.0.10, dst protocol: 192.168.0.254
Jan 17 10:59:33.952:  (C-1) code: no error(0)
Jan 17 10:59:33.952:        prefix: 32, mtu: 17870, hd_time: 60
Jan 17 10:59:33.952:        addr_len: 0(NSAP), subaddr_len: 0(NSAP), proto_len: 0, pref: 0
Jan 17 10:59:33.952: NHRP: Send Registration Reply via Tunnel1 vrf global(0x0), packet size: 148
Jan 17 10:59:33.952:  src: 192.168.0.254, dst: 192.168.0.10
Jan 17 10:59:33.952:      pktsz: 148 extoff: 52
Jan 17 10:59:33.958: NHRP: Receive Registration Reply via Tunnel1 vrf global(0x0), packet size: 168
Jan 17 10:59:33.958:  (F) afn: AF_IP(1), type: IP(800), hop: 254, ver: 1
Jan 17 10:59:33.958:      shtl: 4(NSAP), sstl: 0(NSAP)
Jan 17 10:59:33.958:      pktsz: 168 extoff: 52
Jan 17 10:59:33.958:  (M) flags: "unique nat ", reqid: 231
Jan 17 10:59:33.958:      src NBMA: 172.20.1.49
Jan 17 10:59:33.958:      src protocol: 192.168.0.10, dst protocol: 192.168.0.254
Jan 17 10:59:33.958:  (C-1) code: no error(0)
Jan 17 10:59:33.958:        prefix: 32, mtu: 17870, hd_time: 60
Jan 17 10:59:33.958:        addr_len: 0(NSAP), subaddr_len: 0(NSAP), proto_len: 0, pref: 0
Jan 17 10:59:33.958: NHRP: Forwarding Registration Reply via Tunnel1 vrf global(0x0), packet size: 188
Jan 17 10:59:33.958:  src: 192.168.0.254, dst: 192.168.0.10
Jan 17 10:59:33.958:  (F) afn: AF_IP(1), type: IP(800), hop: 253, ver: 1
Jan 17 10:59:33.958:      pktsz: 188 extoff: 52
Jan 17 10:59:33.965: NHRP: Receive Error Indication via Tunnel1 vrf global(0x0), packet size: 228
Jan 17 10:59:33.965:  (F) afn: AF_IP(1), type: IP(800), hop: 255, ver: 1
Jan 17 10:59:33.965:      shtl: 4(NSAP), sstl: 0(NSAP)
Jan 17 10:59:33.965:      pktsz: 228 extoff: 0
Jan 17 10:59:33.965:  (M) error code: loop detected(3), offset: 84
Jan 17 10:59:33.965:      src NBMA: 172.20.2.85
Jan 17 10:59:33.965:      src protocol: 192.168.0.11, dst protocol: 192.168.0.254
Jan 17 10:59:33.965:      Contents of error packet:
Jan 17 10:59:33.965:         00 01 08 00 00 00 00 00 00 FD 00 BC 84 68 00 34
Jan 17 10:59:33.965:         01 04 04 00 04 04 80 02 00 00 00 E7 AC 14 01 31
Jan 17 10:59:33.965:         C0 A8 00 0A C0 A8 00 FE
Jan 17 10:59:33.965: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 68 00 34
Jan 17 10:59:34.355: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.10
Jan 17 10:59:34.355:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:34.536: EIGRP: Sending HELLO on Tu1 - paklen 20
Jan 17 10:59:34.536:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
Jan 17 10:59:36.912: EIGRP: Sending UPDATE on Tu1 - paklen 0 nbr 192.168.0.10, retry 9, RTO 5000 tid 0
Jan 17 10:59:36.913:   AS 90, Flags 0x1:(INIT), Seq 131/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:37.544: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.11
Jan 17 10:59:37.544:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
Jan 17 10:59:39.009: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.10
Jan 17 10:59:39.009:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:39.166: EIGRP: Sending HELLO on Tu1 - paklen 20
Jan 17 10:59:39.166:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
Jan 17 10:59:40.815: NHRP: Receive Registration Request via Tunnel1 vrf global(0x0), packet size: 108
Jan 17 10:59:40.816:  (F) afn: AF_IP(1), type: IP(800), hop: 255, ver: 1
Jan 17 10:59:40.816:      shtl: 4(NSAP), sstl: 0(NSAP)
Jan 17 10:59:40.816:      pktsz: 108 extoff: 52
Jan 17 10:59:40.816:  (M) flags: "unique nat ", reqid: 1762
Jan 17 10:59:40.816:      src NBMA: 192.168.2.50
Jan 17 10:59:40.816:      src protocol: 192.168.0.13, dst protocol: 192.168.0.254
Jan 17 10:59:40.816:  (C-1) code: no error(0)
Jan 17 10:59:40.816:        prefix: 32, mtu: 17870, hd_time: 60
Jan 17 10:59:40.816:        addr_len: 0(NSAP), subaddr_len: 0(NSAP), proto_len: 0, pref: 0
Jan 17 10:59:40.816: NHRP: Send Registration Reply via Tunnel1 vrf global(0x0), packet size: 148
Jan 17 10:59:40.816:  src: 192.168.0.254, dst: 192.168.0.13
Jan 17 10:59:40.816:      pktsz: 148 extoff: 52
Jan 17 10:59:41.880: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.11
Jan 17 10:59:41.880:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
Jan 17 10:59:41.912: EIGRP: Sending UPDATE on Tu1 - paklen 0 nbr 192.168.0.10, retry 10, RTO 5000 tid 0
Jan 17 10:59:41.912:   AS 90, Flags 0x1:(INIT), Seq 131/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:43.513: EIGRP: Received HELLO on Tu1 - paklen 20 nbr 192.168.0.10
Jan 17 10:59:43.513:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
Jan 17 10:59:43.988: EIGRP: Sending HELLO on Tu1 - paklen 20
Jan 17 10:59:43.988:   AS 90, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
Here is the hub config:
interface Tunnel1
 description ** DMVPN Tunnel**
 ip address 192.168.0.254 255.255.255.0
 no ip redirects
 ip mtu 1360
 ip nhrp authentication DMVPNKEY
 ip nhrp map multicast dynamic
 ip nhrp network-id 1
 ip nhrp holdtime 60
 ip tcp adjust-mss 1300
 cdp enable
 tunnel source GigabitEthernet0/0/0
 tunnel mode gre multipoint
 tunnel key 1
 tunnel path-mtu-discovery
 tunnel protection ipsec profile DMVPN_IPsec_Profile
interface GigabitEthernet0/0/0
 description ** LAN **
 ip address 172.16.0.100 255.255.255.0
 no ip redirects
 no ip proxy-arp
 media-type rj45
 negotiation auto
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
 vrf forwarding Mgmt-intf
 no ip address
 negotiation auto
interface Vlan1
 no ip address
 shutdown
router eigrp 90
 network 10.199.7.0 0.0.0.255
 network 10.200.7.0 0.0.0.255
 network 172.16.0.100 0.0.0.0
 network 192.168.0.254 0.0.0.0
 redistribute static
 passive-interface default
 no passive-interface Tunnel1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.0.1
ip route 10.199.7.0 255.255.255.0 172.16.0.1
ip route 10.200.7.0 255.255.255.0 172.16.0.1
ip ssh version 2
one of the spokes config:
interface Tunnel1
 ip address 192.168.0.13 255.255.255.0
 no ip redirects
 ip mtu 1360
 ip nhrp map multicast "PUBLIC IP hub"
 ip nhrp map 192.168.0.254 "PUBLIC IP hub"
 ip nhrp holdtime 60
 ip nhrp nhs 192.168.0.254
 ip nhrp registration timeout 30
 tunnel source FastEthernet4
 tunnel destination "PUBLIC IP hub"
 tunnel key 1
interface FastEthernet0
 description ** Inside Native Vlan **
 no ip address
 spanning-tree portfast
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 description ** WAN **
 ip address dhcp
 no ip redirects
 no ip proxy-arp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Vlan1
 description ** Inside Net Native vlan **
 ip address 10.40.13.1 255.255.255.0
 no ip redirects
 no ip proxy-arp
 ip nat inside
router eigrp 90
 network 10.40.13.1 0.0.0.0
 network 192.168.0.13 0.0.0.0
no ip http server
ip nat inside source route-map MAP-INTERNET interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 dhcp
route-map MAP-INTERNET permit 10
 match ip address 120
access-list 120 remark List for internet traffic NAT
access-list 120 deny   ip 10.40.13.0 0.0.0.255 172.16.0.0 0.0.0.255
access-list 120 permit ip 10.40.13.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
tbsavcenter
Community Member
Some more log:
Jan 17 11:01:33.985: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 64 00 34
Jan 17 11:01:40.759: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is down: retry limit exceeded
Jan 17 11:01:43.706: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is up: new adjacency
Jan 17 11:02:04.214: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 63 00 34
Jan 17 11:02:33.995: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 62 00 34
Jan 17 11:03:03.218: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is down: retry limit exceeded
Jan 17 11:03:03.273: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is up: new adjacency
Jan 17 11:03:04.001: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 61 00 34
Jan 17 11:03:34.005: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 60 00 34
Jan 17 11:04:04.175: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 5F 00 34
Jan 17 11:04:22.782: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is down: retry limit exceeded
Jan 17 11:04:26.365: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is up: new adjacency
Jan 17 11:04:34.017: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 5E 00 34
Jan 17 11:05:04.021: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 5D 00 34
Jan 17 11:05:34.027: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 5C 00 34
Jan 17 11:05:45.873: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is down: retry limit exceeded
Jan 17 11:05:48.143: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is up: new adjacency
Jan 17 11:06:04.149: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 5B 00 34
Jan 17 11:06:34.037: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 5A 00 34
Jan 17 11:07:04.050: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 59 00 34
Jan 17 11:07:07.651: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is down: retry limit exceeded
Jan 17 11:07:11.223: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is up: new adjacency
Jan 17 11:07:34.049: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 58 00 34
Jan 17 11:08:04.122: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 57 00 34
Jan 17 11:08:30.727: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is down: retry limit exceeded
Jan 17 11:08:31.177: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is up: new adjacency
Jan 17 11:08:34.061: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 56 00 34
Jan 17 11:09:04.065: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 55 00 34
Jan 17 11:09:34.071: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 54 00 34
Jan 17 11:09:50.682: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is down: retry limit exceeded
Jan 17 11:09:50.795: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is up: new adjacency
Jan 17 11:10:04.115: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 53 00 34
Jan 17 11:10:34.081: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 52 00 34
Jan 17 11:10:51.308: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 83 FD 00 34
Jan 17 11:11:06.056: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.11 (Tunnel1) is down: Interface PEER-TERMINATION received
Jan 17 11:11:10.380: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.11 (Tunnel1) is up: new adjacency
Jan 17 11:11:18.306: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.10, code: loop detected(3), (trigger src: 192.168.0.11 (nbma: 172.20.2.85) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 7F 19 00 34
Jan 17 11:11:24.176: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 50 00 34
Jan 17 11:11:34.762: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 50 00 34
Jan 17 11:11:34.798: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is down: Interface PEER-TERMINATION received
Jan 17 11:11:39.170: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is up: new adjacency
Jan 17 11:11:50.532: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 50 00 34
Jan 17 11:12:16.663: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 50 00 34
Jan 17 11:12:51.329: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 4D 00 34
Jan 17 11:12:58.677: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is down: retry limit exceeded
Jan 17 11:12:59.426: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 192.168.0.10 (Tunnel1) is up: new adjacency
Jan 17 11:13:21.335: %NHRP-3-PAKERROR: Received Error Indication from 192.168.0.11, code: loop detected(3), (trigger src: 192.168.0.10 (nbma: 172.20.1.49) dst: 192.168.0.254), offset: 84, data: 00 01 08 00 00 00 00 00 00 FD 00 BC 84 4C 00 34
tbsavcenter
Community Member
Forgot to mention that hub router is isr 4321 running
Cisco IOS XE Software, Version 03.17.00.S - Standard Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.6(1)S, RELEASE SOFTWARE (fc4)
System image file is "bootflash:isr4300-universalk9.03.17.00.S.156-1.S-std.SPA.bin"
and spoke router is:
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.3(3)M6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 04-Aug-15 05:50 by prod_rel_team
ROM: System Bootstrap, Version 15.4(1r)T1, RELEASE SOFTWARE (fc1)
