Bookmark
Subscribe
910
NM-1E or NM-1FE module on a 2620
rwheeler
I have a 2620 non XM (I am upgrading it to the max memory and was hoping to be able to use one of these modules. I have read many of the notes about these modules but some of the info seems to be dated. Does any know for sure if there is a module I can buy to get a second ethernet on my router. I can be reached at jeffrey@anyportinastorm.com
Thank you.
spremkumar
Level 9
Level 9
If you are interested you can check out for Ether Switch Modules which are the new versions of ethernet network modules.
for the support you can refer the below link..
http://www.cisco.com/en/US/products/hw/routers/ps259/products_relevant_interfaces_and_modules.html
regds
scheikhnajib
Mate,
I'm not sure that you can order the FE cards anymore. The new ones are: NM-1FE2W-V2 and NM-2FE2W-V2 and I doubt they will go on the 2620 (not 100% sure).
The NM-1E sounds like a safer option.
Cheers.
Salem.
have that setup running and got the module for $120 from eBay
it works :)
