No data on RSPAN Destination port
denise.fyffe
Quick question.
Should I be able to see the counters increment on a RSPAN monitoring port, see the example below, I have two destination ports going into ISE.  I have been having trouble with DHCP profiling.
I checked that all connections were up for the RSPAN port (its listens to the DHCP server on a different switch)
However, the destination ports on the Switch which hosts ISE, show no data, is this normal?
Session 2
Type                   : Remote Destination Session
Source RSPAN VLAN      : 900
Destination Ports      : Gi1/0/29-30
    Encapsulation      : Native
          Ingress      : Disabled
GigabitEthernet1/0/29 is down, line protocol is down (monitoring)
  Hardware is Gigabit Ethernet, address is 68bd.abc2.631d (bia 68bd.abc2.631d)
  Description: Cisco ISE Primary RPSAN port
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 25w4d, output hang never
  Last clearing of "show interface" counters 16w1d
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
sh int gi1/0/30
GigabitEthernet1/0/30 is down, line protocol is down (monitoring)
  Hardware is Gigabit Ethernet, address is 68bd.abc2.631e (bia 68bd.abc2.631e)
  Description: Cisco ISE secondary RPSAN port
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Last input never, output never, output hang never
ADP_89
To me it looks like your 2 ports are physically down, you should have something like this:
GigabitEthernet1/0/29 is up, line protocol is down (monitoring)
HTH,
ADP
ADP_89
HTH,
ADP
Went to site to find both interfaces with no link lights on the back of the ISE boxes.  Replaced cables, and connection restored.
thank you
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  Last input never, output 02:13:10, output hang never
  5 minute output rate 373000 bits/sec, 200 packets/sec
     1535859 packets output, 358019233 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
#sh int gi1/0/30
GigabitEthernet1/0/30 is up, line protocol is down (monitoring)
  Last input never, output 02:00:11, output hang never
  5 minute output rate 270000 bits/sec, 115 packets/sec
     2 packets input, 176 bytes, 0 no buffer
     Received 2 broadcasts (0 multicasts)
     0 watchdog, 2 multicast, 0 pause input
     806557 packets output, 234926540 bytes, 0 underruns
balaji.bandi
Can you post the configuration to review.
BB
