no intervlan
rk6171485
Hi, I am working for a large campus network. The network has more than 10 VLANS in a Layer 3 Switch(Catalyst 3750). Customer wants to stop intervlan routing between all vlans . How will i do that?
5 Replies 5
no ip routing <<- add this only in SW
habtemariamzebene6612
Frequent Visitor
Frequent Visitor
use the command on global confection mode
"no IP routing"
Joseph W. Doherty
Your large campus network only has these 10 VLANs on just a single 3750 and nothing else using routing on that single 3750?  If so, as the other posters have described, disabling routing should do the trick.  Likewise, if you have no need to route to/from these VLANs, insure there's no gateway (e.g. SVI) on the VLANs.  The latter can still use routing on the 3750 for other purposes, such as management of the 3750.
Also, you have options how those VLANs can selectively route using ACLs and/or VRFs.
Frequent Visitor
Frequent Visitor
only execute the command "no ip routing" in global confugi mode
balaji.bandi
Sure i agree @Joseph W. Doherty  suggestions.
rather disabling the ip routing, i would suggest to have ACL in place or VRF is best way.
BB
