NTP
Hello everybody
so i have been assigned to a task from my manager he wants me to activate ntp on a cisco switch (catalyst  9200 )
i have all the command line but he keeps telling me you are missing something not on the commands but where to apply this ntp on which interface keep in mind we have a local ntp server on our data center , so what concept am i missing i have been searching for a week but i couldn't actually find anything (i read the whole cisco documents).
thanks in advance
balaji.bandi
Sure you need to post the command
Geneally the config you can define as below :
NTP server config
NTP authentication
NTP using source interface
after you configuration do you have ntp association (show ntp association with your local NTP Server ?)
BB
Mark Elsen
             - Post commands tried and the (error) responses you get from the switch ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
balaji.bandi
NTP server config
NTP authentication
BB
