No routing at all
braninl29
I have a 2851 router. Please see the attached configuration file. In attempting to get it to work at all, I have tried both IOS 12.4(15)T3 (ED) AdvancedIPServices and 12.4(18) (LD) IPBase. I have the same problem with both. I have created a very basic config, but can't get routing to work. The configuration of the network is as follows: <my PC> - <2851> - <telco managed router> - <internet>. The IP address of my PC is 10.30.10.55/24. The "internal" address of the 2851 is 10.30.10.5/24, while the "external" address is close to 216.10.10.106/28. The 2851-facing side of the Telco managed router is close to 216.10.10.105/28.
When logged onto the console of the 2851, I can successfully ping my local PC, both interfaces on the 2851, the 216.10.10.105 address on the Telco router and other addresses out on the Internet. However, from my local PC, I can only ping the two interfaces on the 2851 (and other devices on my local network), not the telco interface (216.10.10.105), nor other addresses on the Internet. I am not able to do anything else over the Internet (e.g. browse a website) either.
This seems like it should be the most basic routing possible, but I am simply unable to get it to work. Am I missing something?
Thanks.
Danilo Dy
This is because your PC IP Address is Private IP Address. You need to NAT it to Public IP Address to be able to reach internet.
Dandy
Danilo Dy
Dandy
Branin,
Add the following NAT (PAT) configuration and test.
ip nat inside source list 7 interface GigabitEthernet0/0 overload
access-list 7 permit 10.30.10.0 0.0.0.255
int GigabitEthernet0/0
ip nat outside
int GigabitEthernet0/1
ip nat inside
Sundar
