No Virtual LANs configured on 6500
Courage2020
I've created the VLAN on the Database but it tells me that there are no VLANs configured when i issue the command. Both VLAN 110 and 111 status are down, down. Thank you in advance. Below is my config:
Building configuration...
Current configuration : 15817 bytes
upgrade fpd auto
version 12.2
service timestamps debug uptime
service timestamps log uptime
service counters max age 10
hostname Router
no aaa new-model
ip subnet-zero
ipv6 mfib hardware-switching replication-mode ingress
vtp domain Mariners
vtp mode transparent
mls ip multicast flow-stat-timer 9
no mls flow ip
no mls flow ipv6
no mls acl tcam share-global
mls cef error action freeze
no scripting tcl init
no scripting tcl encdir
redundancy
mode sso
main-cpu
  auto-sync running-config
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
vlan 110
name Data
vlan 111
name Voice
vlan 112
name Video
------------Output Supressed---------
interface Vlan1
no ip address
shutdown
interface Vlan100
no ip address
interface Vlan110
ip address 10.11.110.1 255.255.255.0
ip helper-address 192.168.0.21
interface Vlan111
ip address 10.11.111.1 255.255.255.0
interface Vlan112
ip address 10.11.112.1 255.255.255.0
router eigrp 1
network 10.11.110.0 0.0.0.255
network 10.11.111.0 0.0.0.255
network 10.11.112.0 0.0.0.255
network 172.16.1.0 0.0.0.255
no auto-summary
ip default-gateway 172.16.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.1.1
ip route 10.11.110.0 255.255.255.0 172.16.1.1
ip route 10.11.111.0 255.255.255.0 172.16.1.1
no ip http server
control-plane
dial-peer cor custom
line con 0
line vty 0 4
login
no cns aaa enable
end
lucentmoon
If the vlans created properly in the vlan.dat you should see them in the output of the command 'show vlan'
Also you mentioned the vlan interfaces are down/down.  One of the requirements for a vlan interface to come up is
that you must have an access or trunk port in up/up state.  Can you verify that you have access or trunk ports in up/up state for these vlans?
Under sh vlan, it does show both vlan 110 and 111 as active, but if i issue sh vlans, thats when i get the message
"no virtual lans configured". I'm unable to ping the ip of the vlan. As for the trunk ports, how do i verify it. Thanks
is ip routing enabled: ---> sh ip route
in sh vlan br is there a port number noted next to active? otherwise ---> sh int trunk
is the port in FWD state ---> sh span vlan xx
is there an access port up/up ---> sh int status
Regards.
Alain
No results on the Trunk and Span. Below are the results:
Router#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 172.16.1.1 to network 0.0.0.0
     172.16.0.0/30 is subnetted, 1 subnets
C       172.16.1.0 is directly connected, GigabitEthernet5/1
     10.0.0.0/24 is subnetted, 2 subnets
S       10.11.111.0 [1/0] via 172.16.1.1
S       10.11.110.0 [1/0] via 172.16.1.1
S*   0.0.0.0/0 [1/0] via 172.16.1.1
Router#sh vlan bri
VLAN Name                             Status    Ports
1    default                          active
110  Data                             active    Fa3/1, Fa3/2, Fa3/3, Fa3/4
                                                Fa3/5, Fa3/6, Fa3/7, Fa3/8
                                                Fa3/9, Fa3/10, Fa3/11, Fa3/12
                                                Fa3/13, Fa3/14, Fa3/15, Fa3/16
                                                Fa3/17, Fa3/18, Fa3/19, Fa3/20
                                                Fa3/21, Fa3/22, Fa3/23, Fa3/24
                                                Fa3/25, Fa3/26, Fa3/27, Fa3/28
                                                Fa3/29, Fa3/30, Fa3/31, Fa3/32
                                                Fa3/33, Fa3/34, Fa3/35, Fa3/36
                                                Fa3/37, Fa3/38, Fa3/39, Fa3/40
                                                Fa3/41, Fa3/42, Fa3/43, Fa3/44
                                                Fa3/45, Fa3/46, Fa3/47, Fa3/48
                                                Gi4/1, Gi4/2, Gi4/3, Gi4/4
                                                Gi4/5, Gi4/6, Gi4/7, Gi4/8
                                                Gi4/9, Gi4/10, Gi4/11, Gi4/12
                                                Gi4/13, Gi4/14, Gi4/15, Gi4/16
                                                Gi4/17, Gi4/18, Gi4/19, Gi4/20
                                                Gi4/21, Gi4/22, Gi4/23, Gi4/24
                                                Gi4/25, Gi4/26, Gi4/27, Gi4/28
                                                Gi4/29, Gi4/30, Gi4/31, Gi4/32
                                                Gi4/33, Gi4/34, Gi4/35, Gi4/36
                                                Gi4/37, Gi4/38, Gi4/39, Gi4/40
                                                Gi4/41, Gi4/42, Gi4/43, Gi4/44
                                                Gi4/45, Gi4/46, Gi4/47, Gi4/48
111  Voice                            active    Fa3/1, Fa3/2, Fa3/3, Fa3/4
112  Video                            active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
Router#sh int trunk
Router#sh span vlan 110
Spanning tree instance(s) for vlan 110 does not exist.
Router#sh int status
Port    Name               Status       Vlan       Duplex  Speed Type
Gi1/1                      disabled     1             full   1000 1000BaseSX
Gi1/2                      disabled     1             full   1000 No Transceiver
Gi1/3                      disabled     1             full   1000 No Transceiver
Gi1/4                      disabled     1             full   1000 No Transceiver
Gi1/5                      disabled     1             full   1000 No Transceiver
Gi1/6                      disabled     1             full   1000 1000BaseSX
Gi1/7                      disabled     1             full   1000 No Transceiver
Gi1/8                      disabled     1             full   1000 1000BaseSX
Gi1/9                      disabled     1             full   1000 1000BaseSX
Gi1/10                     disabled     1             full   1000 1000BaseSX
Gi1/11                     disabled     1             full   1000 No Transceiver
Gi1/12                     disabled     1             full   1000 1000BaseSX
Gi1/13                     disabled     1             full   1000 1000BaseSX
Gi1/14                     disabled     1             full   1000 1000BaseSX
Gi1/15                     disabled     1             full   1000 No Transceiver
Gi1/16                     disabled     1             full   1000 No Transceiver
Fa3/1                      notconnect   110           half   auto 10/100BaseTX
Fa3/2                      notconnect   110           half   auto 10/100BaseTX
Fa3/3                      notconnect   110           half   auto 10/100BaseTX
Fa3/4                      notconnect   110           half   auto 10/100BaseTX
Fa3/5                      notconnect   110           half   auto 10/100BaseTX
Fa3/6                      notconnect   110           half   auto 10/100BaseTX
Fa3/7                      notconnect   110           half   auto 10/100BaseTX
Fa3/8                      notconnect   110           half   auto 10/100BaseTX
Fa3/9                      notconnect   110           half   auto 10/100BaseTX
Fa3/10                     notconnect   110           half   auto 10/100BaseTX
Fa3/11                     notconnect   110           half   auto 10/100BaseTX
Fa3/12                     notconnect   110           half   auto 10/100BaseTX
Fa3/13                     notconnect   110           half   auto 10/100BaseTX
Fa3/14                     notconnect   110           half   auto 10/100BaseTX
Fa3/15                     notconnect   110           half   auto 10/100BaseTX
Fa3/16                     notconnect   110           half   auto 10/100BaseTX
Fa3/17                     notconnect   110           half   auto 10/100BaseTX
Fa3/18                     notconnect   110           half   auto 10/100BaseTX
Fa3/19                     notconnect   110           half   auto 10/100BaseTX
Fa3/20                     notconnect   110           half   auto 10/100BaseTX
Fa3/21                     notconnect   110           half   auto 10/100BaseTX
Fa3/22                     notconnect   110           half   auto 10/100BaseTX
Fa3/23                     notconnect   110           half   auto 10/100BaseTX
Fa3/24                     notconnect   110           half   auto 10/100BaseTX
Fa3/25                     notconnect   110           half   auto 10/100BaseTX
Fa3/26                     notconnect   110           half   auto 10/100BaseTX
Fa3/27                     notconnect   110           half   auto 10/100BaseTX
Fa3/28                     notconnect   110           half   auto 10/100BaseTX
Fa3/29                     notconnect   110           half   auto 10/100BaseTX
Fa3/30                     notconnect   110           half   auto 10/100BaseTX
Fa3/31                     notconnect   110           half   auto 10/100BaseTX
Fa3/32                     notconnect   110           half   auto 10/100BaseTX
Fa3/33                     notconnect   110           half   auto 10/100BaseTX
Fa3/34                     notconnect   110           half   auto 10/100BaseTX
Fa3/35                     notconnect   110           half   auto 10/100BaseTX
Fa3/36                     notconnect   110           half   auto 10/100BaseTX
Fa3/37                     notconnect   110           half   auto 10/100BaseTX
Fa3/38                     notconnect   110           half   auto 10/100BaseTX
Fa3/39                     notconnect   110           half   auto 10/100BaseTX
Fa3/40                     notconnect   110           half   auto 10/100BaseTX
Fa3/41                     notconnect   110           half   auto 10/100BaseTX
Fa3/42                     notconnect   110           half   auto 10/100BaseTX
Fa3/43                     notconnect   110           half   auto 10/100BaseTX
Fa3/44                     notconnect   110           half   auto 10/100BaseTX
Fa3/45                     notconnect   110           half   auto 10/100BaseTX
Fa3/46                     notconnect   110           half   auto 10/100BaseTX
Fa3/47                     notconnect   110           half   auto 10/100BaseTX
Fa3/48                     notconnect   110           half   auto 10/100BaseTX
Gi4/1                      notconnect   110           full   auto 10/100/1000BaseT
Gi4/2                      notconnect   110           full   auto 10/100/1000BaseT
Gi4/3                      notconnect   110           full   auto 10/100/1000BaseT
Gi4/4                      notconnect   110           full   auto 10/100/1000BaseT
Gi4/5                      notconnect   110           full   auto 10/100/1000BaseT
Gi4/6                      notconnect   110           full   auto 10/100/1000BaseT
Gi4/7                      notconnect   110           full   auto 10/100/1000BaseT
Gi4/8                      notconnect   110           full   auto 10/100/1000BaseT
Gi4/9                      notconnect   110           full   auto 10/100/1000BaseT
Gi4/10                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/11                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/12                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/13                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/14                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/15                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/16                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/17                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/18                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/19                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/20                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/21                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/22                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/23                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/24                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/25                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/26                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/27                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/28                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/29                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/30                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/31                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/32                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/33                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/34                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/35                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/36                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/37                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/38                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/39                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/40                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/41                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/42                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/43                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/44                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/45                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/46                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/47                     notconnect   110           full   auto 10/100/1000BaseT
Gi4/48                     notconnect   110           full   auto 10/100/1000BaseT
Gi5/1                      connected    routed        full   1000 1000BaseLH
Gi5/2                      disabled     1             full   1000 No Transceiver
Gi6/1                      disabled     1             full   1000 No Transceiver
Gi6/2                      disabled     1             full   1000 No Transceiver
Router#sh vlans
No Virtual LANs configured.
Router#exit
