Not able to configure LLQ for Voice in 6500 series switch
bhalchandrarane
I am facing a issue while configuring Qos for voice in gig port of 6500 series switch.
The error i got is " bandwidth command not supported ".
My configuration is as below:
class-map match-any voice-traffic
match protocol rtp audio
match ip dscp ef
match access-group 171
class-map match-any signalling-traffic
match ip dscp cs3
match ip dscp af31
match protocol h323
match protocol sip
match protocol mgcp
match protocol skinny
match access-group 172
policy-map voice-policy-pmap
class signalling-traffic
bandwidth remaining percent 5
class voice-traffic
priority percent 50
class class-default
fair-queue
access-list 171 permit udp any range 16384 32767 any precedence critical
access-list 171 permit udp any range 3230 3235 any precedence critical
access-list 171 permit udp any range 49152 65535 any precedence critical
access-list 171 permit ip any any dscp ef
access-list 171 permit ip any any dscp cs3
access-list 172 permit tcp any eq 1720 any
access-list 172 permit tcp any range 3230 3231 any
access-list 172 permit tcp any range 11000 12500 any
access-list 172 permit tcp any eq 2720 any
access-list 172 permit ip any any dscp cs3
While i am trying to apply the policy in gig port i am getting the mentioned error. I serached for the document for the ios version and cane to know that bandwidth command is not supported .
My version is " s72033-advipservicesk9-vz.122-33.SXH4.bin ".
Plz let me know any alrenate way to configure the Qos for voice.
It will e very helpful
Edison Ortiz
You are facing a hardware limitation, not an OS limitation, as the regular line cards rely on PFC QoS.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/qos.html
If you want to perform extensive QoS in the 6500 platform, I highly suggest purchasing a SPA/SIP module.
HTH,
__
Edison.
