ssh connectivity lost after power failure
murraythei
Hello all, My first question to this forum, not going to be my last. I'm new to networking at this level.
We have a remote 6506, the entire datacenter lost power due to a UPS failure. Now the 6506 seems to be switching correctly, but can no longer SSH into it, and even thought telnet was turned off - now we can telnet to it.
Is this normal, of all it's configuration parameters it only forgot it's ssh/telnet after a powerfailure?
I want to turn on the ssh and turn off the telnet with out messing anything else up. Any help? Thanks!
6 Replies 6
Collin Clark
If you configured SSH and removed telnet, but forgot to save the config, the switch would use the saved config, not the running config. Check to see if SSH is enabled-
sh ip ssh
If not try configuring it-
SwitchOne(config)#crypto key generate rsa
Enter modulus: 1024
SwitchOne(config)#ip ssh time-out 60
SwitchOne(config)#ip ssh authentication-retries 2
Try the command again to see if it's running-
sh ip ssh
Reply when you get this far and we'll continue to troubleshoot.
This turned on ssh, can now ssh to the switch, but how do you turn off telnet?
Under your VTY's, set the input to SSH only.
line vty 0 15
transport input ssh
You can further restrict who can access the switch by using an ACL and access class under the VTY.
Thanks that did it!
bretjaquish
Level 3
Level 3
Besides checking what Collin suggested, you might want to make sure you saved the SSH keys in NVRAM.
show crypto key mypubkey rsa
If they don't show up, you might have to create new keys.
This is probably a case of forgetting to "copy run".
billy_vaughn
Not sure if this applies here but I've had some issues in the past where I can no longer connect using SSH after a failover or swapping out hardware. Normally recreating the cert fixes it.
As long as you have the following under your telnet lines it should use SSH and not telnet. Remember to put it on both 0 4 and 5 15.
transport input ssh
