Not able to enter Rommon mode in a 3560
afo99
Hi guys,
I bought 2 3560 switches to practice my ccnp switch exam.
However when received those switches and booted them, they were set up with user login details which i don't know of course.
So I tried breaking the boot up to get in to rommon mode so i can make it skip the nvram.
However it is not even letting me do that and proceeds on with with booting.
However i do get an error when loading the IOS, "Error loading "flash:c3560-ipbasek9-mz.122-46.SE/c3560-ipbasek9-mz.122-46.SE.bin"
please see below further:
Boot Sector Filesystem (bs) installed, fsid: 2
Base ethernet MAC Address: 00:23:5d:8a:3c:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 5 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 11774464
flashfs[0]: Bytes available: 4224512
flashfs[0]: flashfs fsck took 9 seconds.
...done Initializing Flash.
done.
Loading "flash:c3560-ipbasek9-mz.122-46.SE/c3560-ipbasek9-mz.122-46.SE.bin"...flash:c3560-ipbasek9-mz.122-46.SE/c3560-ipbasek9-mz.122-46.SE.bin: no such file or directory
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c3560-ipbasek9-mz.122-55.SE6.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
Can you please assist?
Martin L
password recovery should be here
Hold down the mode button located on the left side of the front panel, while you reconnect the power cable to the switch
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/12040-pswdrec-2900xl.html
5 Replies 5
Martin L
it looks like someone updated IOS with 122-55 from 122-46 but it did not change boot command to boot from 55.
it is ok as long as switch loads 55 image.
did u follow password recovery procedures ? probably hold Mode button during initial boot
Martin L
balaji.bandi
Looks like your boot variable set to different one. change as below and test and advise
boot system flash:/c3560-ipbasek9-mz.122-55.SE6.bin
BB
Leo Laohoo
The switch is attempting to load a newer IOS version.
If you want to go into ROMMON you need to hold down the Mode button for about 20 seconds and after applying power.
afo99
Holding down the mode button and going through the password recovery helped.
Thanks guys.
You guys are such legends :D
