Not able to upadate Cisco Packet Tracer Software
As soon as I try to install new version it asks ato login but shows my password as incorrect and I am pretty sure I am entering correct, Though.When I try to reset the password I don't get password reset link in my registered email account.Need urgent Help!
Martin L
after recent upgrade or migration of all Cisco sites to One login, we have some issues with logging to Net academy. if u tried your net academy account with failures, Try using same User ID and password as you have set up for cisco.com site
Note: once you start Packet tracer, close login page, then when asks to save PT file, choose cancel to leave PT running. not sure if you will be able to save Pt work.
Martin L
