04-17-2020 04:04 PM
For a couple years, this switch has been trouble free. Now, all of a sudden I've noticed that it likes to randomly reboot.
If I unplug all cables from it and start to plug them back in, its ok for the first cable. Second cable plugged in... reboots.
Device on the other end of the cable doesn't matter. Even reboots when I plug in both sides of the same cable to two different ports. Switch side port selection doesn't matter either
I have reset to factory defaults, re-flashed with most recent (and second most recent) firmware versions. I also turned off IPv6 and any green ethernet features. Still the same behavior
I'm thinking this switch is experiencing hardware death. Any other things I might try before it goes to the recycler?
Solved! Go to Solution.
04-17-2020 04:42 PM
I think, you are wright. If you have support on it, you can RMA it back to Cisco for replacement, if not it goes to a recycle bin.
04-17-2020 04:42 PM
