NTP Configuration for NX-OS
T_tow
I want to configure ntp servers for my 5ks and 7k.  I have 4 ntp servers.  Would my set up be as follows?:
switch(config)# no ntp server 10.X.X.X prefer use-vrf management    (REMOVES_OLD_NTP_SERVER)
switch(config)# ntp distribute
switch(config)# ntp server 10.x.x.x1 prefer use-vrf management
switch(config)# ntp server 10.x.x.x2
switch(config)# ntp server 10.x.x.x3
switch(config)# ntp server 10.x.x.x4
switch(config)# ntp commit
Would I need anything else?  I don't think I'm fully understanding if the master command would be required or not
Reza Sharifi
Your config should work fine.  To verify peers use.
sh ntp peers
or
sh ntp peer-status
BTW, the command "show ntp status" does not seem to work on Nexus series.
balaji.bandi
here is the sample configuration for your reference :
https://www.cisco.com/c/en/us/support/docs/switches/nexus-7000-series-switches/113585-nex7000-ntp-config.html
BB
Reza Sharifi
sh ntp peers
or
sh ntp peer-status
Thanks Reza!
